Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 41
Thread: r12 system
  1. #27
    Quote Originally Posted by matt1124 View Post
    134a with cap tubes.... thanks for that little gem whoever thought up that combination.... grumble grumble
    quichergrumblin
    You're working, aren't you?
  2. #28
    May 2011
    Oklahoma
    Yep, and so is that fridge
  3. #29
    Jun 2012
    az
    Is there anything that can clear that wax?
    Sent from my SCH-I510 using Tapatalk 2
  4. #30
    Quote Originally Posted by Phase8 View Post
    From a cap tube?
    Nope.
  5. #31
    Aug 2010
    From a cap tube?
    Nope.
    There's a tool that you attach to a cap tube and push it out with thousands of psi with oil or solvent. It's pressurized with a screw down oil pump or hand driven hydraulic pump.
    It was in the same refrigeration and HVAC book that talked about cutting open a hermetic compressor for repair.
  6. #32
    Jan 2010
    Quote Originally Posted by ICanHas View Post
    Yep and it's called CAP-CHECK m#1003 by Thermal Engineering
    Also check out the CAP-CHECK CHASER KIT m#1101
  7. #33
    Jun 2012
    az
    Thank you.
  8. #34
    Oct 2011
    Chicagoland Area
    Or...wait for it...just change the cap tube.
  9. #35
    Jun 2012
    az
    Quote Originally Posted by 2sac View Post
    Easy to say, but when there is no space to move around in and the cap tube is brazed to the suction line from beginning to end having more options is always nice.
  10. #36
    Jul 2005
    Tulsa
    Quote Originally Posted by Russ57 View Post
    R-401A runs a little lower head/hot gas temp so I like it a little better than R-409A. Both work fine though. No need to change TXV. I use 100% alkylbenzene oil. MP39 is claimed to work just fine with mineral oil (IIRC).
    have used R409A and R401A without changing TXV. both work fine
  11. #37
    Oct 2008
    Changing the cap tube is still the best option since you're assured of "fresh from the factory" passage of refrigerant. If they brazed the cap tube to the suction line as a heat exchanger, duplicate it by making a new line set. The cap tube doesn't need to be brazed to the suction line. Soldering the lines together will serve the same purpose, requires less heat and far easier to apply.
    "You never know what others don't know." -
    If I can't laugh at myself...then I'll laugh at YOU! -
  12. #38
    By the time you're done fiddling around with that cap tube cleaner widget, I've got 2 of them done and I'm off on a third call.
  13. #39
    Jan 2010
    Yeah that widget does look like a glorified bottle jack for a lot more money
