Page 1 of 4 1234 LastLast
Results 1 to 13 of 41
Thread: r12 system
    r12 system
    I have a 3 door reach in cooler with a bad compresor. Ive never ran into this before. Whats my options as far as putting in charge
    California
    Lots of options out there.
    I like MO49 primarily
    or
    401a for medium temp applications
    401b for low temp applications
    What about the expansion valve. I can use the same???
    Apr 2011
    I have several jugs of R12. Some for sale too!
    Sep 2010
    miami,fl.
    Quote Originally Posted by FL.HVAC View Post
    im also in the south florida area im in miami just curious to know what part of town your in??? nice to see others in the area on here
    Apr 2012
    winnipeg
    I use R-414B - 100 % success
    Ft myers. But im in boston now
    Apr 2012
    Jackson, MS
    If I was going to change the compressor I would convert to 134A. While u have the compressor out just fluah it with rx11 and pull a good vacuum.
    Apr 2012
    winnipeg
    134a is the last refrigerant i would use....
    Oct 2011
    Chicagoland Area
    409a
    Apr 2012
    Jackson, MS
    Why not 134A it's apparently using a txv most of the problems I have with 134A come from cap tube systems and waxing I have the same issues with all refrigerants using poe oil and cap tubes.
    Apr 2012
    winnipeg
    134a leaks where other refrigerants do not.... i quit using it years ago ...hate the stuff
    I would say 401a but to each his own. I'm not a fan of hot snot or 134a. I've had issues w/ cap tubes & TEVs on anything running w poe including rtus .. We all know what the high temps do.
