Results 27 to 39 of 96
Thread: Appion vs C&D
05-29-2012, 09:46 PM #27
- Oct 2010
- 10
I got on the appion wagon too after reading all the good reviews. I have the same problem with my Appion CRT's, they will not pull a core. I also bought the 1/2" hoses w/ 3/8" x 1/4" fittings and the brass crimp was jacked up on both hoses. They should've noticed the bad crimp when they were in QC. I traded the hoses in for YJ 1/2" x 6'. I've tested my C&D CRT with 500# of pressure under water w/ no leaks.
05-29-2012, 09:56 PM #28
Dudes ,
Rock on with the " brand B ". I have a good thing going with the Appions , but I'm not getting paid you know. If there is a faster train , you know I'm jumping on. From what I've seen of the other stuff it's just a barge of trash , but heck , I'll be watching. Live Free Brothers - t45
05-29-2012, 10:48 PM #29
- Jan 2005
- Akron
- 790
This may not seem like Rocket Science, (vacuum) but I have proof it is.
http://engineer.jpl.nasa.gov/practices/1223.pdf
The Appion tools are designed for vacuum, the lower the vacuum rating, the faster you can pull the vacuum and the better the results under a standing pressure test. I did forward the Video to Appion.
We sell a lot of core tools and have not had any complaints of this problem. I do know however that every core is not exactly the same. It could be simply the tolerance of the core that was being tested and or even the brand of equipment that you install and the cores that come with it.JLB- Co Owner TruTech Tools Inc.
05-29-2012, 10:53 PM #30
From left to right Appion New Version, Appion Old Version, C&D
I shot a video of one new version that is broken in and one new version that is basically out of the box. I'll see if I can't get it posted up. The old version worked just fine and still does. The C&D feels so sloppy the end is about to fall off and just barely holds a core.If You Can Dodge A Wrench You Can Dodge A Ball
05-29-2012, 11:14 PM #31
It would take a rrreeeeeaaaaalllllllllyyyyyyyy lllllllllloooooooooooooooooooonnnnnnnnnnnnnnnnnnng gggggggggggggggg ttttiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii immmmmmmmmmmmmmmmmmmmmmmmmmmmmmeeeeeeeee to measurably reduce the volume of the refrigerant oil in the system with a vacuum pump.
05-30-2012, 06:42 AM #32
- Nov 2011
- Charleston, Wv.
- 792
yeah that's kinda what I was figuring too.
05-30-2012, 07:09 AM #33
This video has a new version with the stainless steel shaft with raised lip and light weight knob
I bought two and they both did the same thing. One is broken in and the other is still tight. My original Appion with the brass shaft never was an issue out of the box. I get how a guy would be pissed about it but to say they are better than the C&D's that will fail long before the Appion is a little silly. I haven't messed with the stiff Appion so maybe there is a drill size that will loosen them up quicker but my offer still stands. I'll trade you any day.
05-30-2012, 10:05 AM #34
No return.
- Jul 2006
- NW burbs of Detroit
- 6,058
05-30-2012, 10:10 AM #35
No return.
- Jul 2006
- 6,058
05-30-2012, 10:27 AM #36
No return.
- Jul 2006
- 6,058
I don't completely agree with you on your "the lower the vacuum rating the the faster you can pull a vacuum" statement. There are too many variables that effect evacuation time to make such a broad claim, and your generalization favors Appion for un-scientific reasons.
And tell me what listing agency or lab varied the 20 micron claim?
I learned a long time ago not to take all the specs a mfg attributes to his product with a grain of salt. There is a lot of marketing strategy and broad, some times thin, claims made about a lot of instruments capabilities in our trade.
05-30-2012, 10:47 AM #37
If only one thing is different how could there be too many variables Clover?
If you got one system on any given day less leaky equipment will pull faster than equipment with more leaks. If you chose tighter equipment you will pull faster than if you didn't. Could be anybodies stuff. Not brand specific. I laughed about the vacuum rating too when they said the only ones vacuum rated and thought well nobody felt the need to rate them before so I guess they could be the only ones vacuum rated LOL
BTW where did you get the rating you posted on the C&D? Mine only came with a paper sheet with the part #'s in the little bag they were hanging on the shelf.If You Can Dodge A Wrench You Can Dodge A Ball
05-30-2012, 01:50 PM #38
Hey Jim .
I was contacted by Christian today from Appion , and was told there IS a ISSUE with the New Appion Core Removers with the 2 Rubber O Rings , they will be sending me out 2 new Re-Developed Plungers to compare . Me & Eddie will Perform a Comparison Video for Everyone to see . I have pulled several Deep Vacuums with the Tool on Installations along with my Vacuum Rated Appion Hoses and Blanked Off and Held my Vacuum . The tool is Fantastic for Vacuum , my only issue was Removal .
They stated they were using New O Rings that , were within tolerance but they Push the Pin rather than Roll around it the way they are supposed to .
Thank You very much for taking the Time to View my Video and Email to Appion . I will forward the New Comparison Video directly to you Sir !!!
Fritz ...
05-30-2012, 02:11 PM #39
No return.
- Jul 2006
- 6,058
