Page 2 of 8 FirstFirst 12345678 LastLast
Results 14 to 26 of 96
Thread: Appion vs C&D
    Oct 2011
    Arkansas
    Quote Originally Posted by chuckcrj View Post
    What other kind of valve is there for crt? All I've seen so far have ball valves.
    This one is like my Robinair. I use it for is replacing bad cores. Worked fine now for 20yrs.
    http://www.southsidecontrol.com/acat...D3900_690.html
    In a machine room
    Quote Originally Posted by AC5096 View Post
    Interesting. Learn something new everyday.
    NW burbs of Detroit
    You gotta ask??????
    Nov 2011
    East Side
    that 20 micron thing is nice i guess, but supposedly, you risk boiling/evaporating the refrigerant oil past 250 microns.
    I like my appion!
    My pump wont pull to 20 Will the Appion pump pull down to 20?
    In a machine room
    Quote Originally Posted by hvaclover View Post
    You gotta ask??????
    Is that a problem?
    Worry is a really gross misuse of one's imagination. -- PHM
    May 2009
    South of Heaven
    I've seen 50 on mine ( tez 8 ) , and I've seen 30 on a JB 10 cfm.
    The Appion crt 's are RATED to 20 microns ( in response to others being rated to whatever number ). I mentioned the 20 micron rating and it added mess to the mess.
    NW burbs of Detroit
    Quote Originally Posted by tech45 View Post
    Who rated them to 20 microns?
    I know the package says they are, but what nationally recognized agency lists them as being tested and approved to hold at 20 microns?
    If they have no agency listing Appion could just be blowing hot air.
    You don't need anything lower than a 200 micron vacuum. Any thing lower is just bragging rights and provides no extra benefit to system dryness.
    Maybe but any of these rated valves will just get worse over time and if you were starting out at 20 you got a head start on one that is starting out at 200
    I've seen a video from the guy in the OP and his pump will pull down to zero so there
    On a side note it sucks how his videos get taged so when I'm looking for one from someone like JimB. all his pop up about something not even close to what the search was about. If you're reading this could you tweek the tags alittle fritz unless you're making money off the videos then have at it I guess
    In a machine room
    You gotta ask??????
    Is that a problem?
    Help me out here, hvac lover. Just curious what was wrong with my question.
    In a machine room
    Is fritz and hvac lover the same person?
    I highly doubt that
