    Question low oil flow latching alarm
    hi every one,
    i am facing an diagnostic issue in my RTAA 217 trane chiller with low oil flow alarm first i thought that came to my mind was that oil filter was dirty hence hence 1) i changed the oil filter along with new oil but still problem persist,
    2) then i checked for differential pressure switch since the diagnostic alarm is "low oil flow" then in order to check wether the DPS is working properly or not i changed DPS ..........but still the problem continues
    plz advice.......
    and i am very new to this forum .........
    Feb 2012
    EVERYWHERE
    You would have saved money and time if you would have called someone that knew how to work on a RTAA. Also would have helped if you put this in Chillers not Residential.
