Results 1 to 13 of 15
    Dec 2011
    louisiana
    testo hook broke
    Anyone know a fix for the flimsy aluminum hook on the back of the Testo550? I love the gauges but the hook sucks. Broke off at the ball. Need to hang my gauges.
    Stupid design and I think it is just pot metal. Somebody had cost cutting in mind instead of durability!!
    Call Testo and they should send a new one, it is a common issue. Probably have pallets full.
    South Carolina
    Quote Originally Posted by pacnw View Post
    um wondering how you know?? call testo ; they will take care of you just like the ppl at digikewl
    It is what it is unless I say differently !!!!
    I store, transport, and work with my Testo 550 in a padded case, and recommend that others learn to do so too.
    Testo makes nice instruments, but they are padded case instruments.
    My first generation Testo 523 still works as good as the day it was made, but it basically is never fully removed from proximity to its padded case. Even when I hang it, the case is positioned under it.
    My 2nd gen 523 died 4 times under warranty before I gave up on it and quit sending it in.
    It never had a padded case.
    My 550 broke from a 16 inch fall off the top of a refrigerant tank, so I got a padded case for it, which I believe will be the key to getting a useful service life out of it.
    Mar 2009
    Mid-Mo
    Im on #4 with mine. 2 broke hanging on units and the other I had them laying in a bucket and tossed some stuff in on top of it and snap!
    Jun 2006
    Torrance, Ca
    Funny, both my SMAN3 and AK900 have taken 4 foot falls off condensers. I don't think it left any discernible marks. I'm to clumsy for a Testo.
    Dan
    If you don't notice, I'm doing my job.
    Quote Originally Posted by derb View Post
    Dan
    practical application outside of lab conditions is not the place for Testo.
    as Mark said, Testo DRSAs have been a poor choice for field work. I have the 2nd gen 523 and had similar issues. Testo refused to fix it the last time, still under warranty, yet they said tuff !!
    wedged in freezer shelf
    Any of these broken hooks the new hook that is thicker?
    I guess they made some improvement to the hook but it didn't sound like it would fit the original case
    My first gen 523 rolls around in the back of my truck and dropped a few times right on the hook and all good. The second gen 523 hook I thought was silly but is heavy duty compared to the new hook.
    I wish they sold more when they were better so now we have less choices today. The stuff that matters has gotten so freggin cheap to hit that price everyone wanted to buy
    Even the Digicool hook is not what it used to be. The old one was the eight wonder.
    I guess this is what the majority of guys wanted so can we complain lol
    The pipe temperature sensor for my first generation 523, due to both the overall design of the probe, and that it is a platinum based PT100 sensor, is the most accurate and precise pipe probe I've ever used.
    It is also almost as convenient to use as a pipe clamp type probe.
    Unfortunately the replacement cost of just the probe was/is close to the cost of what an entire DRSA + 2 probes are now!
    I really like both my Digi-Cool BTD-1000 and DRSA-1250 because the instruments themselves are extremely durable, but the temperature probes for the 1250 have been a real letdown.
    I may try again with some new probes now that they are using better wire, but I also want to separate the probes into 2 separate plugs.
    Dec 2011
    louisiana
    re-made testo hook
    I had to have a hanger so I just made one, took about 15 minutes. I just got an eyebolt, welded a bigger head on the end and ground it round and rebent the ends. This one won't break. If you don't have a welder, just silver solder the ball shape.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	2012-05-26 19.40.21.jpg
ID:	265611   Click image for larger version.
Name:	2012-05-26 19.40.54.jpg
ID:	265621   Click image for larger version.
Name:	2012-05-26 19.53.31.jpg
    Thumbs up
    Wow Looks good enough to rip the back of the unit off now
    Dec 2011
    nothing like a airborne 550 falling into some compressor drive belts to wake you up on a cold frosty morning.
    But seriously we work around moving machinery TESTO should have sorted it long ago.
    Mar 2009
    Mid-Mo
    I had hopes that #4 would come with something different to keep that from happening....and when it didn't, it is what it is. That hook that you have made......wow
