Page 3 of 5 FirstFirst 12345 LastLast
Results 27 to 39 of 60
  1. #27
    Apr 2003
    Originally posted by yocona
    What do you mean by "unclick the Yahoo toolbar"? Also, maybe you have some sort of firewall preventing the download. Or an anti-virus program that isn't allowing it? Are you aware if either of these might be the case?
    At any rate, here is the Flash info page if you are having trouble with the install: http://www.adobe.com/cfusion/knowled...fm?id=tn_19166
    This is where Yahoo toolbar comes into play.
    This window comes up when you click on "Flash Player Download Center" on the link you provided.
    There shouldn't be any firewall or antivirus issues at this time.
  2. #28
    Apr 2003
    Originally posted by icemeister
    Try this one:
    http://www.adobe.com/support/flashpl...loads.html#fp8
    Click on "Get the Latest Version"
    Takes me to the same page with the Yahoo toolbar ad.
    No worky.
  3. #29
    Nov 2005
    Originally posted by Jultzya
    Hey gone, why should we have to update?
    What version of vBulletin are they using?
    I don’t think we should have to up date. If this site is now
    more about the ads, than the people who make the site
    what it is……….well I say there are other good choices now.
    I brought this up a couple weeks ago too.
    http://hvac-talk.com/vbb/showthread.php?threadid=108645
  4. #30
    Okay, now I see what you mean by the Yahoo toolbar. I don't see why that would have any effect.
    One other thing I can think of is to check your Internet Security level setting. To do that, go here:
    Start/Settings/Control Panel/Internet Options
    Click on the Security Tab. This may look a little different depending on exactly which version of Windows you are running. On XP Pro, I have two buttons--Custom Settings and Default Settings. When I click on the Default button, it shows me a slider that lets me set the security at Low, Medium, High . . . If you have it set higher than Medium, this could be preventing the download. If so, move it down to Medium, click Apply then click OK. Then try the download again.
  5. #31
    Nov 2005
    Yeh, there ya go. Change this, change that, open up security
    level, download this download that, up-grade here upgrade
    there, welcome to Penton media hell..........
    IT JUST AIN'T THAT IMPORTANT ANYMORE!!!!!!
  6. #32
    Jun 2001
    Louisville, KY
    Then, quit clicking on the site if it's just so damn bad. Sheesh.
  7. #33
    Nov 2005
    Thanks for that ya prick. Consider it done.
  8. #34
    Apr 2003
    XP Pro... was on custom. Changed it to Med.
    Got the download after 3 tries... but, now have this problem when I go to install it.
    What a MESS!
  9. #35
    Nov 2000
    Coastal Georgia
    Explorer crashing
    Maybe it is the Firestone tires
  10. #36
    What a MESS!
    [/B]
    Did you try just clicking on that Install button? If so, what happened?
    I just downloaded the current version on my husband's system (the XP Pro computer) using IE. It took a couple of tries, but finally got it. Anyway, at least I can see where the files should be installed. So if it hasn't worked for you yet, we can check your My Computer directory and create the proper folder if it doesn't already exist.
  11. #37
    Apr 2003
    It brought up a bar and installed them (I guess) then nothing happened after that... the screen above and the install bar just disappears.
    I know this didn't do anything as your link still says I have 7.0.19.0 installed and IE has crashed probably 10 times since then.
  12. #38
    Okay, try this. In your IE browser window, click on Tools then choose Internet Options. Select the Security tab and then Internet, and make sure that you have these options selected:
    Active X controls and plug-ins
    Automatic prompting for ActiveX controls: Enable
    Download signed ActiveX controls: Enable
    Run ActiveX controls and Plug-ins: Enable
    Downloads
    Atomatic prompting for file downloads: Enable
    File download: Enable
    This is how I finally got it to download/install using IE.
    [Edited by yocona on 07-08-2006 at 12:59 PM]
  13. #39
    Midwest
    yocona: Thanks for the links and advice. I was able to upgrade my Firefox Flash Player and it no longer crashes.
    There was also a security issue with my old version according to them.
