Results 14 to 22 of 22
    The Hot South
    Quote Originally Posted by valdelocc View Post
    My guess would be, you liquid charged it too fast washing away the oil and bearings seized up, the funny noise was the liquid refrigerant slugging the compressor, by the time it stopped all the oil was gone.
    X2
    Dec 2010
    San Bernardino, CA
    Quote Originally Posted by R123 View Post
    X2
    X3
    Contactor chattering, you sure its not single phasing?
    up in the hizzy
    Quote Originally Posted by whiteside2831 View Post
    X3
    I think is a single ph unit cause the external overload, chattering could be due to the locked compressor drawing high amps trying to star and voltage taking a dive. with the limited info provided everything is a guess.
    Rocket, try reversing star and run, turn it on and hit it hard with a 2X4
    May 2012
    San Diego, CA
    If it isn't an electrical problem, I would agree with valdelocc. Check your refrigerant charge. Also the problem could be contamination in your refrigerant line. Check your filter/dryer, if your refrigerant is entering the compressor with contaminates or still in liquid form then that is bad for your compressor. Not enough refrigerant in your compressor could be causing the overheating.
    Nov 2009
    wasilla, alaska
    Write this down-ALWAYS check your power coming in. Then check the contacts on the contactor and power at the motor (compressor). Also never run anything that is over RLA. Also when it stopped what did it stop on? Thermal overload or phase monitor? A safety or did a winding burn apart? What kind of compressor? Ohm out windings. Lost a leg on the 3 phase? Is it 3 phase? More info=better answers.
    Nov 2011
    Yes it is 3 phase, What i think happen is that flooded the compressor on start up and cooked the compressor bearings, i am going to pump it down. realse the pressure and open the head. I wish it was an electrical problem but seems like i am going to have to replace the compressors maybe??? , compressor tries to start but doesnt crank over.
    up in the hizzy
    Quote Originally Posted by rocket600 View Post
    have you try reversing the rotation?
    Nov 2009
    wasilla, alaska
    No oil pressure switch? Takes a while to seize em up on washed oil.
    Jun 2012
    mmmm, liquid slug...ouch.
