Results 14 to 26 of 29
    In a machine room
    Quote Originally Posted by jnsrose View Post
    I could only find one on ebay for 120 bucks.
    Do a search on eBay for the item number kiwireeferman posted.
    Worry is a really gross misuse of one's imagination. -- PHM
    Jun 2002
    south jersey
    Ok I found it using your item #.
    You need to put the phone down and get back to work!
    Mar 2006
    New Zealand
    Jul 2005
    So do we have the ok to get one or you still testing?
    You should wait. I've only used it four times, and today it failed an accidental drop test. Seems it isn't impact resistant plastic. A small sliver of plastic snapped off of the outer jaw cover. I fixed it with super glue, good as new. Next time it might not fare so well. We'll see. But, since I had to disassemble it to make that repair I went ahead and took some pics of its innards.
    I stretched the spring out about an extra inch to give it more clamping strength because it was a little whimpy. Feels just like a Fluke 80PK-8 now. I also glued the sensor cup to its plastic holder (the black ring) to prevent the sensor from turning in the clamp.
    Mar 2006
    New Zealand
    That looks like an ambient sensor just behind the holes in the case.
    Picture 3
    Reference junction?
    Jul 2005
    Quote Originally Posted by kiwireeferman View Post
    Picture 3
    Yes, looks like the reference thermistor. The holes/ vents (on both sides) appear to be dual purpose. You can hold it up to the light and see the thermistor midway between them.
    Jul 2005
    This is an update. Don't buy this piece of junk. The plunger handle has broken off, and the calibration is off by as much as 7°. It has only been used about a dozen times and hasn't been abused. It also sometimes reads 32° out of the blue for no apparent reason.
    Rejected!
    To top it off, the supply house wants to replace it rather than issue a refund or exchange. I told them I would never use the replacement because it's just junk. I guess I'm getting a replacement anyway. I'll probably toss it right in the dumpster, package and all.
    NH
    Bummer... Maybe Cooper will make one with a bigger screen now.
    May 2009
    South of Heaven
    Is it Deaded ?
    Sorry , I was just looking for a reason to use that term
    Jul 2005
    No, just piece of crapped.
    Jun 2002
    south jersey
    Can I have it? lol Thanks for the update. Was actually just looking the other day on sleezebay and considering the purchase. Guess I will have more money to spend on my new fairing for my Harley.
    Mar 2006
    New Zealand
    Quote Originally Posted by hvacrmedic View Post
    Rejected!
    Why chuck it in the dumpster, if it has warranty, just use it till it breaks and then get another replacement. A test of patience between the seller and buyer. (grin)
