Results 1 to 13 of 28
    Boise, ID
    Chiller bearings
    Can anyone tell me what maintenance difference there would be with going with magnetic bearings vs conventional? Looking some 300 ton Yorks. The cost difference is not that much. Need to know for a life cycle cost analysis. Thanks in advance.
    Politicians need to be changed like diapers, and for the same reason.
    Mark Twain
    oil side maint goes away. but electronics are more robust. I think the glued on bottle cap goes away....
    winter work essentially the same
    Jersey
    make sure you have reliable power before installing a mag bearing unit, the coast down bearings for power failure are one time use, after a no power coast down you need to rebuild it and replace them.
    Jan 2011
    Quote Originally Posted by DFZ
    With regard to the York YMC², that statement is just not true. There is some capacitor storage that aids in coast down. I think the quote was 10 "hard" landings.
    My opinion of the YMC² is that it didn't have sufficient reliability testing before it's release. I am also of the opinion that the YMC² is pricey. I find it interesting when you say there isn't much difference in price. 'Round here we find them to be at a premium price.
    Boise, ID
    There was a difference of roughly 3 grand, which IMO is peanuts for a 25-30 life span. The owner is interested in life cycle costing so I am trying to find out if they require more or less maintenaince.
    Mark Twain
    Aug 2011
    York, PA
    Quote Originally Posted by KnewYork View Post
    I agree that these ymc units did not have sufficient testing, I worked with one of the first in service at a local college, POS! It has gotten better, but I still would not put my trust in one of these machines yet. just my opinion. This machine has had a few hundred or more hard landings, the bearings still seem to be ok.
    Aug 2011
    York, PA
    Quote Originally Posted by Legacy80 View Post
    there were also issues "A LOT" with the drives on these chillers.
    Jan 2011
    Quote Originally Posted by Gib's Son
    I wish I could see the model numbers and the quotation...it's not that I don't believe you. I'd want to show them to our equipment sales rep. We pay about $100/ ton more for the YMC².
    Boise, ID
    Mag bearings have been around for a long time, in the Navy and marine world from what I understand. Seems to me the first time I heard of commercial HVAC applications was about 10 years ago. Idaho is about 10 years behind the rest of the country. LOL. That's what it felt like when I move here anyway.
    So far I am getting it's about a push for maintenance, and you better have good and reliable power.
    Mark Twain
    Jan 2011
    That stuff about York using mag bearings in the Navy chillers is 100% and I repeat 100% BS. York has not used magnetic bearings other than a couple of OM systems. I would shy away from the York offering and use a chiller with Turbocor compressors if I absolutely had to have magnetic bearings.
    if you are concerned with lifecycle costing, you should take a serious look at the smardt machines paired with a cpecs control ackage. The total plant package will give you very good performance numbers that many wont believe.
    The york machines still have some bugs that others have gotten past. Real good power is critical, with no noise on your ground whatsoever.
    Boise, ID
    Ok, a few more questions: What is a "hard landing"? I have an idea, but do not want to assume...we all know the saying. What is the YMC2?
    I'm not sure if owner is locked into York or not. Only that they looked at screws vs cyntrif. and decided upon the latter. This is a Govt. job so scrutiny is....well, typical of Govt. jobs. I just don't have the first hand working knowledge of this stuff as my career path has taken me away from allot of hands on work. I appreciate all of your input!
    Mark Twain
    Aug 2011
    York, PA
    York just started using the mag bearings in the navy chillers, there are none installed on any ships yet.
