Results 14 to 19 of 19
    ottawa canada
    Is the vent line solenoid valve the Trane OEM valve and which way does the flow arrow point on it .. To the suction cover or to the oil sump ??
    Aug 2000
    Austell, Ga.
    Wow.....30 minutes and you lose the entire oil charge. You posted that the compressor was just rebuilt. On that I must ask if the bearing cap and gasket was replaced behind the Ball bearings. Thats the one with the six long threaded studs that go the the rear bearing web. The clearance on that bearing cap to the rotor shaft is extremely close and is often overlooked.
    I did a CVHE1250 and screwed up not replacing it. Strangely it also took 25-30 min to dump all 7 gallons...
    Ain't "None" of us as smart as "All" of us..
    Jan 2012
    Arrow points to suction cover and it is oem. Also, i only replaced the gasket. May have been a mistake. It wont lose all 7 gls. in 30 minutes but you can clearly see oil level dropping pretty fast, so i just shut down. But, in the return line sight glass for the thrust bearings you can see a good return to the sump.
    Jan 2012
    Update: Problem solved. It was the vent line valve not working. Sounded good but nothing going on inside. Pressurized machine and replaced valve and its running great. Thanks for the tip nuclrchiller
    Aug 2009
    Prattville, Alabama
    Quote Originally Posted by djones View Post
    You're welcome, glad it helped.
    Not in Iran
    nice
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
