Thread: mcquay roof top ac
07-05-2006, 11:11 AM #1
- Jan 2006
- 129
Walked up on a mcquay unit that was calling for both cmpressors to run and only one was running. I had a wiring diagram for the control circut and used that to find the problem. This thing was off on low pressure. I hooked suction and this thing nearly pulled into a vac. Ok tracing out piping from condensor i saw some solenoids before txv. I can find no wiring diagram for the solenoids in the unit. I wish i had a model but forgot to get. This is your usual publix ac with heat reclaim and is a 500 series store. My question is why is there a solenoid downstrean in piping before txv? Whats the order of operation after the condensor in cool mode? I think if i know how this systems works after the condensor i might have a chance to figure it out. Thanks for the help....
07-05-2006, 06:23 PM #2
- Dec 2004
- new jersey
- 70
is the one solenoid off the discharge line and tee's into the distributor at the outlet of the txv? if it does it is for hot gas bypass capacity control, not sure what you are exactly asking?
07-06-2006, 06:26 AM #3
- Jul 2005
- FLORIDA
- 1,162
hey ice
depending on the unit it may have two solidnoid coils in there
one is for a main pump down for the ac, so when your calling for ac that valve should be energized, if not it pumps down and the low presure switch takes out the compressor's
should be an 20/80 25/80 fixed screwed into the head
the second is for what they call a smart coil for helping with dehumidity control or the second stage ac on the board if it gets to hot in the store they can by pass that coil for all the cooling they can get
these types have unloaders also run off a adjustable low presure control where the compressor contactors are located
this all depends on the age and modelonce you think you've seen it all
(THINK AGAIN)
I would rather work for free than be look upon as a thief!!!!!
07-06-2006, 06:29 AM #4
- Jul 2005
- FLORIDA
- 1,162
hey ice
depending on the unit it may have two solenoids coils in there
one is for a main pump down for the ac, so when your calling for ac that valve should be energized, if not it pumps down and the low pressure switch takes out the compressor's
these types have unloaders also run off a adjustable low pressure control where the compressor contactors are located
(THINK AGAIN)
07-06-2006, 04:29 PM #5
This may have info you can use as well.
http://www.chillergroup.com
Terry McIver, executive editor, Contracting Business magazine.
07-06-2006, 04:46 PM #6
- Jan 2006
- 129
I have to get back and look at this thing again. If i remember right i did see two coils. I guess with both stages calling the coil directly in the liquid line should be energized. Stage two is running fine. My only problem is with stage two. What energizes the pump down coil?Originally posted by dirtyboy103us
hey ice
