+ Reply to Thread
Results 1 to 7 of 7
Thread: ball bearing failure and blower wheel seperation.
    May 2012
    Our tech did a spring service on 5 packaged York units. He replaced fan belts and I confirmed proper tension. About a month later 2 units had issues. One has a destroyed ball bearing that came apart and the other has a blower wheel that separated from shaft. What are some common reasons this would happen? The York units are within ten years old.
    Mar 2010
    Kent, WA.
    the bearing that came apart, was it on the drive side or opposite side. proper tension can be a broad term. on packaged units proper tension is like almost a loose belt. if it squeels at startup your probably ok. the bearings on the 3/4" shafts on most small capacity packaged units are not that durable and too tight of a belt can destroy them. considering the age of the units you probably got the life out of those little bearings.
    I have seen blower wheels come loose so i tend to check the setscrew on them during a major pm.
    May 2012
    Bearing failure on both units are on opposite of drive side. And the blower wheel got completely beveled out.
    up in the hizzy
    A month is way too long to blame it on the tech, in my opinion the failures are not related to what the tech did although he may had missed the trouble signs.
    are you sure they were "ball bearings"?
    May 2012
    The actual balls of bearings were on the bottom of unit. I know our client is questioning if our service caused these issues. I can certainly see how put on a new snug belt will bring to face these issues that were doing ok on old loose and worn belt.
    New Mexico
    Ball bearings are designed fer a radial load. In other words straight down. I might look at the blower sheave not running true or the fan riding it's fan curve causing side thrusting.
    Over lubing can pop the bearing seal and allow contaminants in.
    We are here on Earth to fart around ......Kurt Vonnegut
    You can be anything you want......As long as you don't suck at it.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
    Sep 2006
    Ohio
    If belts are rolled on without loosening the motor, it can cause bearing damage. That being said, even if he rolled them on, the bearings were most likely going out anyways.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
