Results 1 to 13 of 19
    NW burbs of Detroit
    SMAN being excangerd again
    I turned on my SMAN yesterday. With nothing hooked up my SH was reading 18*.
    Called fielpiece they are sending me another new one
    WTH is going on? Starting to have a crisis of faith concerning Fieldpiece.
    Don't think I'm the only one.
    In a boiler room
    What does excangerd mean?
    If you get a digi cool you only need one set.
    Worry is a really gross misuse of one's imagination. -- PHM
    What does nothing hooked up mean? What did you expect it to be reading? Are you sure you weren't looking at a calculated target superheat?
    Well I'll be John, I don't wander in here to much but it is a pleasant surprise to see your still amongst us old grunts.
    Hello Hello Hello
    Arlen.
    Expect nothing, yet expect the unexpected.
    Press on Regardless, Endeavor to Persevere.
    NW burbs of Detroit
    Quote Originally Posted by chuckcrj View Post
    sending me anew one overnight UPS...for that I am grateful to Fieldpiece.
    i
    Oct 2007
    Anaheim, CA
    Quote Originally Posted by hvaclover View Post
    It is not uncommon to see a SH reading when the SMAN is not hooked up to a system. Depending on the refrigerant, that number could be different. If the pressure and temperature match up to a value on the PT chart, it will show the result. In your case, Pressure is "0" psi and temperature is ambient. Check your PT chart for whatever refrigerant you had selected and see if 18 looks about right.
    Travis
    NW burbs of Detroit
    No ...the display showed hi and lo gauge press, SH and SC.
    Clamps and hoses were parked on SMAN. All above showed 0 psig and SC was Ol...SH was measuring 18*.
    Called the factory they told me to return it.
    Oct 2011
    Arkansas
    What do you expect from an instrument that looks like Sponge Bob on life support.
    NW burbs of Detroit
    What I expect is what I am getting...people willing to to the hilt to get my analyzer right.
    Still not enough info to call it bad like Travis said. Do you still have it?
    If this keeps up you'll be back to testing with a wet finger and light bulb wiggy
    NW burbs of Detroit
    Quote Originally Posted by ault51 View Post
    Travis
    410A and ODT was 59*F. IDA was 78*F with 65RH..
    Not sure how those coditions could give me 18*sh
    Caledonia WI
    Quote Originally Posted by AC5096 View Post
    Now that you mention it I can clearly see the family resemblance. I can't wait until they start selling their full Sponge Bob series staring accompanying tools shaped like all of Sponge Bob's friends. Kudos To Fieldpiece on the great marketing ploy designed to capture the hearts and minds of the Sponge Bob generation.
    NW burbs of Detroit
    Travis
    Over looked one detail....there was no residual vapor in the SMAN3 as I urge the lines before
    i put them in my ABM1 case...
    ...that would have been the only other thing I can think that would give me a reading of temp.
    thank you for filling me in on that Travis.
