Page 3 of 3 FirstFirst 123
Results 27 to 33 of 33
  1. #27
    Jan 2011
    North Carolina
    Nevermind, sorry guys....didn't quite see the post about it being the variable orifice motor. Maybe next time...
  2. #28
    Jun 2012
    Knoxville
    I had same problem. High oil temp when running below 40% load, unit would shut down 180 deg. plus. We found Refrigerant level control turned off. After all this work to find problem, it was something simple.
  3. #29
    Cleveland,TN.
    York's don't leak oil they MARK their spot
    Sent from my SM-G930V using Tapatalk
  4. #30
    in a tree looking in your window
    Quote Originally Posted by frick View Post
    You went back 5 years to tell us that ? Thanks man
    If you dont stand behind our troops, please feel free...........to stand in front of them.
  5. #31
    Apr 2016
    Maryland
    I work at a facility that only specs YORK ( over 80 chillers on site from 40 up to 1500 ton ) ! Most CRITICAL APPLICATIONS that I have seen are YORK . NEVER seen anything on a ship that wasn't a YORK or FRICK !
  6. Likes valdelocc liked this post
  7. #32
    up in the hizzy
    Whats also great about York is parts availability, unlike Trane they will sell you any chiller part,tool,software etc. no need for secret handshake, all they want is $$$$, York also has more technical info on their website than any other chiller manufacturer.
    There is not better place for the working men than the union! 100% UA the only HVAC union!
  8. #33
    Jan 2013
    United Kingdom
    You should ensure the metering valve is fitted correctly and that a physical level of 1/2 a sightglass in the condenser is maintained, don't be fooled by seeing liquid refrigerant splashing around on the bottom of the condenser level sightglass and thinking this is a true level, the curve of the shell allows liquid to drop into the sightglas, raise the level a little using the level control on the condenser screen if the level does not come up, typically try 5% increments then wait and see, monitor the condenser sub-cooling too and the evaporator and condenser small temp difference, plus the oil temp too of course.
Tags for this Thread
