Results 1 to 13 of 15
05-21-2012, 12:37 PM #1
New Guest
- May 2012
- 4
Fieldpiece Wireless Digital Multimeter LT17AW
Anyone having trouble with the the wireless on this meter? Here is a video I did wireless always losses connection.
02-20-2013, 08:40 PM #2
- Oct 2012
- Torrington CT
- 74
has any one had good luck with this meter i am thinking of buying one
02-21-2013, 09:42 AM #3
Professional Member*
- Jan 2012
- Blairsville ga.
- 22
I am looking at buying also. I have used fieldpiece for many years and really like it. I already have some attachments I used on old stick meter so I assume they will work on the wireless.
02-21-2013, 05:35 PM #4
- Oct 2012
- Torrington CT
- 74
i looked in to some more and i like it i got it from http://shop.rdholder.com/Digital-Multi-Meters_c8.htm i got 5% off with the code hvactalk i will let you all know how i like when i get it
02-23-2013, 08:55 PM #5
- Feb 2013
- Summerville SC
- 81
I have this meter and I absolutely love it. I have never had problems with the wireless sync losing connection however the further my meter is from what im trying to read it tends to show no reading. Ex. I give the amp probe head to my helper to check the blower amps and static pressure while im working on the condenser on start up and say from 50 feet away I will never see anything pop up.i walk inside and when I step through the door the reading picks up.
03-01-2013, 05:24 PM #6
- Oct 2012
- Torrington CT
- 74
Well i have used the new meter for a week it took a little bit to work out the wireless and the heads. I have never had a fieldpiece heads before so that took a little getting use to. I like them a lot they make a good meter. I lost the wireless signal a few time but it all worked out.
03-01-2013, 05:40 PM #7
- Jan 2012
- Blairsville ga.
- 22
That's good to hear mine should be here Monday.
03-15-2013, 04:40 PM #8
- Oct 2012
- Torrington CT
- 74
ok so i have used the meter for a little bit now and when i try to use the amp probe with the wireless i get the no sink and i have to re connect it to the meter is there any fix for the meter or do i have a bad transmitter
03-15-2013, 05:01 PM #9
- Oct 2008
- Fullerton
- 714
03-15-2013, 05:17 PM #10
- Jan 2013
- 970
03-15-2013, 05:48 PM #11
- Oct 2012
- Torrington CT
- 74
i just called up they where very helpful i will have to send in the meter and they will send me a new one i like how they help me out i really like the meter so i will really like it more when it is all working right
03-15-2013, 06:06 PM #12
- Oct 2008
- Fullerton
- 714
03-15-2013, 07:07 PM #13
- Jan 2013
- 970
