Results 1 to 10 of 10
Thread: Rheem Broken Nut
05-20-2012, 11:03 PM #1
- Aug 2008
- 212
Rheem Broken Nut
I go on a no cooling call, find a 2 year old Rheem Split Heat Pump flat on charge. Dump in the nitro to find it will not hold any pressure at all. I go to the AHU and find the TXV Nut split open. Rheem will not warranty this because it is "Commercial" The AHU is a residential 3 ton AHU with a 3 Phase condenser. Replaced the coil, drier, vacuum and 9 lbs R410A. All working well for now.
05-21-2012, 04:34 PM #2
The unit or application is "commercial" ? They don't warranty their commercial stuff? Maybe someone got Rheemed.......
05-21-2012, 04:46 PM #3
- Aug 2008
- 212
Rheem Commercial warranty is 1 year. This is a residential AHU in a commercial application. It should at least keep its 5 year parts warranty. This is the living quarters for our local Fire Dept.
05-25-2012, 02:39 PM #4
I'm about sick of Rheem's warranty coils. We have changed at least 10 this year that was 7months - 4 years old. I did a few with in the first year, so I had the privilege of covering the labor, freon and dryer. Thanks Rheem!
Perhaps the need to lay of the Tequila at there Mexican manufacturing plant.
05-26-2012, 10:56 PM #5
- Aug 2008
- 212
05-29-2012, 04:14 PM #6
When't on one today we installed about 2 years ago found the leak in the condenser coil.
05-29-2012, 06:17 PM #7
I always use an ADP coils with Rheems. They are much less restrictive and now come in the same color.
Sent from my iPad using Tapatalk HDTo the man who always did it right. I love you dad and I will miss you to much for words.
Stay Thirsty My Friends
Support the Skilled Trades Don't DIY
05-29-2012, 06:21 PM #8
05-29-2012, 06:22 PM #9
Wow. Last Rheem call a made was a flat 5 ton with a leak at one of the compressor spot welds. NotbRheems fault but still unusual.
06-06-2012, 01:04 AM #10
Been finding a lot of leaky rheem evap. coils unit are only 1-3 years absolutely horrible.
