Results 27 to 30 of 30
Thread: Mitsubish Mini-Split
02-16-2013, 01:10 PM #27
Professional Member*
- Oct 2009
- Raleigh, NC
- 455
I know this is an old post, but how come no one really made any comments about the previous fuel usage in this space? If they used $1500 of LPG for heat, probably using an unvented heater, then they were losing a lot of heat. It doesn't seem possible to burn that much LPG with a single wall heater in one season. If they doubled their electric bill with a one-ton window unit AC, then they are gaining a tremendous amount of heat in the summer. This electric usage also seems impossible, unless they have a VERY small "normal" electric bill for their home. Why will this install pay them back anything really, unless they tighten the space up?
02-16-2013, 04:21 PM #28
It,s a garage.
02-16-2013, 05:05 PM #29
- Oct 2009
- Raleigh, NC
- 455
I can see that, but that isn't my point. If they used a tremendous amount of fuel in both summer and winter before the mini-split, they are still going to use almost as much now, maybe a little more if they had an unvented LPG heater before. Why would you spend, I'm guessing, nearly 3K on an installed mini-split when you should get insulated garage doors with that money instead?
02-17-2013, 09:46 AM #30
Because the cost to BTU ratio of propane is insane compared to the cost to BTU ratio for minisplits.
Also, because air sealing a garage with an unvented heater is the worst thing you can do. The only thing keeping those people from dying is the high ventilation rate of a garage."Better tell the sandman to stay away, because we're gonna be workin on this one all night."
"Just get it done son."
Dad adjusted
