Results 1 to 13 of 18
Thread: 1.5 T 14 SEER or 2 T 16 SEER?
07-03-2006, 10:39 PM #1
- Jun 2006
- 18
Replacing an old 1.5T HVAC unit upstairs that has 3/8and 5/16 Line set.
Option 1
Replace with a new 1.5-ton, 14, SEER, Lennox unit (Freon 22) and a 80% Variable speed gas system, with out changing the line set. (Cheaper by 2500$) (1100 Sq. Foot upper floor)
Option 2
Replace with a New 2 ton 16 SEER Lennox/Trane unit (410a) that requires addition of new line set, couple of additional supply vents, and one return vent. Expensive by 2500$
Contractor 1 recommends option 1, but willing to do option 2
Contractor 2 recommends option 2
What are your thoughts
07-03-2006, 10:41 PM #2
- Sep 2002
- I don't know
- 2,888
If your current 1.5 ton unit cools properly, don't upsize. Oversized systems consume more energy and don't remove enough humidity.
07-03-2006, 11:28 PM #3
- Jun 2006
- 18
Even a .5 Ton increase can affect humidity and energy ?
07-04-2006, 12:17 AM #4
Professional Member*
- Nov 2004
- SW FL
- 5,355
Location?Originally posted by nagaseth
Option 1
What are your thoughts?Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
07-04-2006, 07:30 AM #5
My take, option 1 if you have had satisfactory cooling with 1.5 ton before.
07-04-2006, 08:04 AM #6YES!Originally posted by nagaseth
07-04-2006, 08:17 AM #7Its possible.Originally posted by nagaseth
.5 ton is 33% increase on a 1.5 ton.
If the 2 ton unit is 2 stage, then you should have no trouble.
07-04-2006, 11:19 AM #8
- Jun 2006
- 18
My Location : North Metro Atlanta
I was thinking that 2T with 16 SEER is a better choice because 1) Energy saving 2) Better cooling 3) Latest Technology
I now realize that 1.5T is the ideal unit after reading all your opinions. Why dont manufacturers make 1.5T with 16 SEER rating ?
07-04-2006, 11:20 AM #9
- Jun 2006
- 18
Sorry, I for got to add. 2T is two stage (Trane XL16i)
07-04-2006, 12:19 PM #10
2 Ton 2 stage is the better choice so you get the high seer.
07-04-2006, 12:27 PM #11
2 ton 2 stage is better then 1.5 ton single stage.
07-04-2006, 01:26 PM #12
I finished my 950 square foot bonus room on the 2nd floor of my house and installed a heat pump myself.
The load came to just under 1.5 tons so I installed a Trane XL14i 1 1/2 ton w/ a variable speed ahu.
I really wish I would've used the XL16i 2 ton 2 stage because when I have company over or when its 95+ degrees it does have a little trouble keeping up with the demand.
07-04-2006, 01:41 PM #13
- Jun 2006
- 18
Why cant contractors quote separately for the unit and separately for Installation. This way I know how much a XL16I costs and how much they bill for installation
Is it customary in HVAC field that prices are kept confidential? So that customer cannot compare the cost effectiveness of contractors
