Results 1 to 7 of 7
    May 2012
    Return Duct Size
    Been doing a bunch of reading on here, but still am a bit confused on return duct size.
    I have a 5 ton AC unit, and I have 3 return ducts throughout the house, the filter sizes are as follows:
    (1) 20x25
    (1) 12x12
    (1) 12x12
    Grills are slightly larger than the above filter sizes, so they fit in well.
    It seems that the return size recommendation is between 144 and 200 square inches of return per cooling ton. My calculation appears to be 157.6 sq inches of surface area per ton. (500+144+144=788 /5)
    I think my vents are somewhat loud, not howling, but very noticeable. I appear to be at the low end of the recommended size range, but they should be perfectly acceptable baring any duct problems right?
    Arizona
    At a minimum you should have 1000 sq inches of RAFG area for 5 tons. Or in other words (2) 20x25 RAFG's
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Mar 2009
    Mount Holly, NC
    the filter sizes you have, will whistle and plug up very quickly.
    there is a difference between Return ductwork area, and return FILTER area.
    the minimum filter area recommended by ANY system manufacturer is 200 sqin/ton. I prefer 350/ton. because this gives room for filtrete filters, and longer filter change intervals, along with quieter system operation, and longer system life.
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    SW Wisconsin
    Hart&Cooley 'Return Air Filter' Engineering Data for 300-fpm filter Velocity
    They recommend at least 2-cfm per sq.in., I prefer at least 1.5-cfm per sq.in.
    5-Ton @ 2000-cfm / 1.5-cfm per sq.in.= 1333-sq.ins.; & that is not enough for a 'low pressure drop media type filter' for 300-fpm initial velocity...
    Actually Hart&Cooley Engineering Data for an initial 300-fpm filter velocity it takes (2) 30X24 filters (or 6.3-Ak,sf total) or 'nearly' 1440-sq.ins. for 2000-cfm. 2000-cfm/1440-sq.ins. or, 1.38-cfm per sq.in. of 'physical' filter area.
    You'll never end-up with too much RA filter area for those larger tonnages...
    Jun 2010
    Philadelphia PA
    More than the size is the location
    With the filters in the grills instead of in the unit, the chances are the resistance of the duct to those remote 12x12's is probably not allowing them to be very effective.
    The proof in the pudding is what is your negative pressure reading at the unit.
    If it is higher than the supply then trouble
    Mar 2009
    Mount Holly, NC
    Quote Originally Posted by udarrell View Post
    true information, but most homeowners are unaware of the airflow rate of their system.
    they all know "tons of cooling" that's why I posted the stats my way.
    I like big filters, placed to get the most function and least noise!
    I am yourmrfixit
    May 2012
    thanks for all the replies. The future may have testing and larger returns installed if the existing ducts allow for it.
