+ Reply to Thread
Results 1 to 11 of 11
Thread: Buffer tank job
    May 2012
    Upper Michigan
    Buffer tank job
    Lady had a 60k boiler with a 10k load. This one was tight.
    Attachment 276681Attachment 276691
    Jul 2012
    ontario canada
    as a rule i always try and mount the expansion tank in the vertical plane, maybe i'm old school as the kids say
    otherwise stellar work, i bet that boiler is way happier with the extra volume
    May 2012
    Upper Michigan
    I've never heard that about exp tank but I will keep that in mind thanks.
    May 2012
    Upper Michigan
    Also the boiler sounded rough until th buffer tank, then she purred. Everyone else wanted to sell them a new boiler, we said this is what you need, customer for once listened lol.
    Jul 2012
    ontario canada
    boilers are like dogs, give them a job to do that occupies them correctly and they're happy .. if you don't they usually end up peeing all over your floor
    May 2012
    Upper Michigan
    Exactly ^^^^
    Aug 2001
    Pavilion, NY
    What is the theory? I assume the boiler was cycling on and off limit very quickly and the buffer tank allows more thermal mass to prevent this?
    May 2012
    Upper Michigan
    Quote Originally Posted by kangaroogod View Post
    To stop an oversized boiler from short cycling and premature failure. Most systems are over sized and have lots of issues.
    I have a bad feeling about this high eff oversized equipment, I see future problems.
    Aug 2001
    Pavilion, NY
    I have never seen or heard of this before. How is this piped? Storage tank in series with supply/return of boiler and system secondary piped?
    May 2012
    Upper Michigan
    Ya it's basically the primary loop, there are 4 bungs the Side against the wall is the secondary side. They can be a pain to wire. I have to think every time I install one lol. You would be doing homeowners a service to recommend them, they also se you apart from the competition. I know we are the only shop using them, this was my second one.
    A Noisy Compressor Room
    Quote Originally Posted by KlRadiant View Post
    Haha I like that!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
