Results 1 to 4 of 4
Thread: "The Hook"
    Question
    Had a salesman come in the other day and sell me these torch tips called "the hook" said they would heat the pipe evenly around the pipe. Tried the large one but keeps blowing the flame out on a 7/8 line. Not sure if I am doing it correctly. oxy @ 25 acet @ 7-8. Not all the orfices blow out but seems to be the end one, 4 on the lg. one and three on the samller one. Anyone else use this and how does it work for you?
    There is no off switch to the genius mind!!
    Motors run on smoke!! When the smoke comes out of it, it needs a new one!
    Jul 2001
    turn your oxygen down to about 12-15.
    Jul 2005
    I used uniweld's captin hook....worked ok...not realy great...emptys a take quick fast and in a hurry
    Im a newbe....and I found with the hook, I did not better and no worse job than I do with a single flame tip...sometimes 1 or more holes lose their flame and it can be a pain relighting them....also when ...as a newbe will from time to time....you make the torch "pop"...with the hook you get a series of pops like a string of firecrackers....it will get the old timers hart rate up...and they will come see what the new guy done when and blew up
    Bottom line other than some very special situations I realy see no advantage to this product....but thats just me.
    73% of Americans say that illegal immigration is a problem. The other 27% say, "No habla inglis!"
    they need to make a "hook" torch tip which works from 1/4" up to 7/8". I would like that. Cause that serves most of our general lite commercial/ residential work.
    I have only used the little hook. I like it.
