There's a short delay before the blower comes on. That's normal with the Goodman air handler. The hissing at the end of the cycle is the normal movement of refrigerant through the system as the high and low side pressures begin to equalize. Refrigerant just likes to move a lot and will continue even with the system off, constantly migrating from warmer to cooler areas. You just don't hear it unless it's moving under high pressure, which it is at the end of a cycle.
