Results 1 to 7 of 7
    Sep 2011
    California
    Picard Bowl lift
    Anyone had work on this type of equipment.
    Mod LP-2800BL Ser. 1190980
    220-240V charger. 12VDC system.
    Having problems with the Tilt return. The tilt down is no problem.
    NE Alabama
    Limit switch maybe
    Sep 2011
    Maryland
    How does it tilt? Is it a toggle switch? We work on a lot of savage Bros. bowl lifts and this switch goes out over time.
    Sep 2011
    California
    Yes, I replaced them with a selector switch with a spring return.
    Sep 2011
    California
    Sep 2011
    Maryland
    That works a little different then Savage Bros. in that the Picard is using a relay to reverse the direction. Is it possible that the gearbox is causing a binding on tilting back up?
    Sep 2011
    California
    Quote Originally Posted by Ovenguy View Post
    I added a diode this way i would not make a short circuit. When i changed the direction of the motor.
