Results 1 to 13 of 14
    Question Please
    What causes compressor burnout, and how do you tell if that has occured?
    Florida
    Alot of things. Acid in the system,excessive temps,factory faults,mis- wiring,low voltage,voltage spikes,etc.
    You can tell when compressor doesn't run, and you open system up to acidic conditions(contaminated freon).
    Most common cause: incompetent installation, followed by poor service.
    If the contactor at the compressor is energized but nothing is happening, no fan, no cold refrigerant to the coil, nothing, would this be compressor burnout?
    Probably not.
    Sounds like it is time to call a professional.
    Yes, I intend to. Air handler cfm increases as usual(York variable speed blower), but zilch at the compressor. As an electrician, after the contactor is energized and pulled in, that is where I make the handoff to you HVAC guys!
    In most cases, high temperature, FOLLOWED BY acid formation.
    How can you tell? If the compressor refuses to start, check for acidity.
    http://www.air-conditioner-selection...intenance.html
    Nov 2000
    Eastern PA
    The term "burnout" is used way too much in our industry for referring to simply failed compressors. A true burnout condition is quite easily identified by the acrid odor of the refrigerant oil and the acidity of that oil as well as the discoloration.
    Without an oil sample, there is no way to determine if the compressor is a burnout.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Louisiana
    I totally agree.
    Sure there is. Disconnect the wires to the compressor and measure it with a multimeter. It won't be able to tell if it's an actual burnout, but it can tell if it's bad.
    Interesting. What should be the estimated reading be? Maybe I can learn something new . Let's hope that this is not DIY.
    Pretty simple. A (less than infinite) reading from any terminal to ground is bad. Then check winding resistance to make sure it matches up to datasheet specifications. It won't be able to tell if a turn or two is shorted, but that's when more sophisticated test equipment comes into play.
    I would hope that posting a link to public information otherwise available by a simple search would not be a violation of the Forum rules.
    http://www.inspect-ny.com/aircond/ai...htm#aircond1D3
