Results 14 to 26 of 45
    Southeastern Pa
    Quote Originally Posted by flanders View Post
    Sorry that it took me so long to reply. When I arrived back on the scene the unit had new problems. Blower still was not running but now the reset button on the economizer was tripped. I reset it and the unit cycled off on high pressure. I found that 1 of the 2 condenser motors is bad. I replaced the motor and dual capacitor (10/10 mfd) on Friday. With the economizer reset and the new condenser motor, it seemed to operate fine. I waited for about 30 minutes and then I split. I am going back this afternoon to check on it again (and drop the bill off). Even if everything is fine, I am still concerned with the economizer reset being tripped. I will keep you posted.
    P.S. Something else that I found was that someone jumped out the board where the 5V fuse is supposed to be so there must have been a low voltage problem before me.
    Do you have a pic of where you "reset the economizer?" That's a new one for me...
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Southeastern Pa
    You could throw on a "lil popper 5 amp" till you find your problem. Provided the first one you try blows.
    Good idea. The lil popper is perfect for the Carrier RTU board.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    up in the hizzy
    Quote Originally Posted by timebuilder View Post
    That must be a Resi thing. Not true on the RTU's.
    some Carrier RTU's do need 24v at G for the compressor to run, I've worked in a few of them.
    Southeastern Pa
    Quote Originally Posted by valdelocc View Post
    Post a model # when you have a chance. I've never seen one.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jan 2010
    So if you were to set the t-stat to fan on the compressor will start ?
    Or are you saying Y & G at stat ?
    up in the hizzy
    nope mechanical cooling control interlocked with fan contractor, very simple stuff! sooner or later you'd run into one.
    If you jumper R to Y at the board of the RTU. The compressor won't run, unless the blower contactor is in also.
    First time you run into one, it throws you off.
    Mar 2010
    Arnold, Mo
    I just left there. Blower was off again, condenser fans running, compressors funning. No voltage to the blower contactor. Inside the return side at the filter, there is a box that looks like it is the economizer to me. I'll take a picture and post it. The reset button was tripped again. I pushed the button and "presto", the blower kicks on. I didn't get to stick around to find out what is causing it to trip.
    East of big city prices.
    What's the economiser board look like?
    Southeastern Pa
    Are you saying the Y1 call is broken over an aux switch on the blower contactor????
    What model is it?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Mar 2010
    Arnold, Mo
    Quote Originally Posted by Dallas Duster View Post
    When I go back I'll take a picture.
    up in the hizzy
    I think hes talking about a smoke detector, thats would kill the blower when tripped.
    Philadelphia PA
    the smoke detector should be breaking R, not just G
