Results 1 to 4 of 4
    Model R Trane Compressor Top-End
    How difficult is it to do a top-end on a Trane Model R Compressor in the field ?
    Estimate on Parts ?
    How many hours to complete on average ?
    Compressor is tripping off on motor winding temperature. Discharge Line temp is running 375 .Suspecting broken valves in the compressor. I have replaced a broken Rod on a Trane E compressor,but never tore-into a Model R before. What can I expect?
    Does the Model R have the giant springs in the head of the compressor?
    Jan 2010
    Did you rule out all other possibilities ? How about some pressure readings,type of refrigerant etc.
    Nov 2013
    Anthem, AZ
    What is your compression ratio?
    Dec 2003
    45th Parallel
    I wouldn't do a top end without taking a peek in the bottom also. Just to CYA, check for broken rods, plugged oil screen... etc.. I would say a couple days, unless site conditions and access are perfect, then maybe a day of bustin A**. But then when you start bustin A**, thats when you miss something that bites you later. Then you have a busted A**, and one with a big bite out if it!! Oh, and YES, big springs! Don't want Trane permanently imprinted on forehead....
    “If your work speaks for itself, don't interrupt.” ~Henry J. Kaiser
