    Aug 2009
    West Coast
    York YKCFCFQ-CNFS
    Hi
    Does anyone know were to get a good O&M
    on this chiller
    I have the 220 page Optiview but it doesn't
    do the trick
    I am looking for the factory charge for this machine
    its not on the nameplate
    thanks guys
    Jan 2011
    You want FORM 160.73-O2 (605) available on JCI's website. You didn't write the number for the compressor code. I'm assuming it's a Q7. With C-C shells it should have a charge of 1,600 lbs.
    Aug 2009
    West Coast
    Hi KnewYork
    My compressor Model Number is
    YDHF52DD
    I have a leak on the oil return line service valve on the back of the oil sump. Its threaded into a female pipe fitting and it doesn't show a o-ring or gasket on the parts list. Do you know if its leak tight on the threads?
    Its the line coming from the bottom of the cooler barrel with the filter dier and solinoid valve and then into the sump
    Spencer
    Jan 2011
    Quote Originally Posted by spencer91 View Post
    YDHF52DD
    No leak tight! All fittings on YKs should either have teflon seals or o-rings. Check out this parts list and see if you can identify the fitting you are seeking.
    Aug 2009
    West Coast
    Thanks KnewYork
