Results 1 to 6 of 6
    May 2012
    Toronto, Canada
    Carrier 30HC chiller startup probs
    Having trouble establishing oil pressure on startup after extended shutdowns. Thinking of adding a heater to the condenser shell to keep refrigerant out of the oil. Experience???
    Dallas ,Texas
    What do you mean by extended ? Both circuits ?
    May 2012
    Toronto, Canada
    Off for the winter. Both circuits. Last few years we have been able to start by running hot water through the condenser, cold water through the evap before startup. This year still fails to establish pre-start oil pressure.
    Dallas ,Texas
    Open your exv's up and run cold water thru the condenser. Your oil has migrated to the condenser. You must have the fist sized prelube pumps.
    May 2012
    Toronto, Canada
    I'll try it. Yes, I have the fist-sized pumps. Thanks. We have the same problem when the machine cycles off on cool days. Any prevention?
    Dallas ,Texas
    Quote Originally Posted by ChillerMike123 View Post
    Keep the condenser cooler than the evaporator. I have one that migrates every year . I just pump it over once a year.
Quality Home Comfort Awards
