Results 14 to 26 of 53
    Apr 2012
    Paper Street Soap Company
    Quote Originally Posted by qwerty hvac View Post
    I'm 6'5" 300lbs. I don't think I will be crawling in there. Lol
    Sent from my iPhone 4s
    using Tapatalk
    Im 6' 6" 250.
    Ive done three. Im in my early 40s though.
    Ive seen people jerry rig txvs into tgose units.
    Its easier to get the manifold in.
    Apr 2012
    Quote Originally Posted by timebuilder View Post
    Nope.
    Flip out the condenser fan and get inside on a set of kneepads. Done a couple that way.
    Is that a piper sitting on top of a grumman cheetah in your avatar ?
    Dec 2008
    Buffalo NY
    Quote Originally Posted by commtech77 View Post
    nice set of guages
    Thank. 550 testo. I had the analogs out to recover but did not get a pick. Hopefully it is just the drier and I won't have to crawl in.
    using Tapatalk
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Southeastern Pa
    If I recall from the news story, it's a Piper Arrow atop a Cessna 152.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Southeastern Pa
    using Tapatalk
    It's like a submarine hatch.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Dec 2008
    Buffalo NY
    This is true. I will check it out and see of I can get in there.
    using Tapatalk
    Jul 2005
    Here are some numbers:
    SH 8.5
    SC 28.6
    High side 199.6
    Low Side 48.3
    Ambient temp 72.7
    Condenser discharge 92.7
    Supply temp 41.5
    Return temp 67.1
    compressor discharge temp 71.8
    suction temp 33.1
    I'm guessing compressor discharge was 92.7 and LL temp was 71.8?
    Your numbers are telling me floodback and low indoor airflow. 0° SH instead of 8.5°. There can be considerable measurement error on a package unit if you don't insulate your sensors to the line.
    Are you sure it was completely thawed out?
    East of big city prices.
    Quote Originally Posted by hvacrmedic View Post
    Yeah I'm not seeing a restriction with 8.5 degree superheat.
    Dec 2008
    Buffalo NY
    It had thawed because I disconnected second stage and let first cool the space. I was also think low airflow but first stage was working fine. I want to check above the ceiling on Monday and look at the ductwork. I know it has a hard return with flex to four 16" round 2 x 2 grills. Maybe the return is insulated on the inside? I want to see.
    using Tapatalk
    That subcooling is pretty darn high that's for sure. I like the testo display. If i didn't read so much more negative than positive about them i would of went with them
    Jul 2005
    using Tapatalk
    First stage would have more air forced through it if the second stage portion of the coil was iced over. Now that the coil has thawed the first stage SST is probably running low too.
    Quote Originally Posted by hvac wiz 79 View Post
    Subcooling is high because it's a fixed orifice. With a 25 degrees delta T I would say airflow too.
    Apr 2012
    Usually when those manifolds go south its just one or two metering devices and its almost impossible to clear the restriction.
