Page 1 of 5 12345 LastLast
Results 1 to 13 of 53
    Dec 2008
    Buffalo NY
    Question Carrier RTU second stage freezing up
    Model # 48HJE014x-5006238
    Serial # 4309G40674
    Get a no cooling call at 4:30 yesterday, find second stage compressor and evap coil frozen solid. I figure low on charge,late in day. So I pull up the recovery machine and all my crap to see what is left in the system and recharge for the weekend. Well I pull out the charge and get 9.2 lbs and stop. Factory change is 9.4 I believe. I let it thaw, dump the charge back in and let it fire up. While I was doing all of this by the way I had first stage running and it cooled off the space. So it runs for about ten minutes then starts freezing. I am thinking a restriction in this stage somewhere. I have numbers out in the truck. Figured I would post this to get some thoughts.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Nov 2007
    Mississippi
    Liquid line drier restriction.
    Apr 2012
    Paper Street Soap Company
    That RTU has the manifold with the crimped in metering devices right ? Could be the liquid drier too.
    Ive replaced that manifold metering assembly a couple of times because one or two of the met. devices were plugged.
    Pull the drier and check it.
    Dec 2008
    Buffalo NY
    Quote Originally Posted by commtech77 View Post
    That is what I was leaning towards. I did not take a temp drop across it. One of those days where I just wanted to get home.
    Dec 2008
    Buffalo NY
    How big of a job is it to pull that manifold? I have not had to do one yet.
    Dec 2008
    Buffalo NY
    Here are some numbers:
    SH 8.5
    SC 28.6
    High side 199.6
    Low Side 48.3
    Ambient temp 72.7
    Condenser discharge 92.7
    Supply temp 41.5
    Return temp 67.1
    compressor discharge temp 71.8
    suction temp 33.1
    Dec 2008
    Buffalo NY
    Attachment 262601Attachment 262611Attachment 262621
    Some pics.
    Sent from my iPhone 4s
    using Tapatalk
    Apr 2012
    Quote Originally Posted by qwerty hvac View Post
    They're pretty easy actually.
    You have to cut the old one out and I then remove the stubs with a torch. It doesnt take a lot of heat and then slide in the new manifold and replace the old drier.
    I use 15% and light heat.
    Easy peasy japaneasy
    Apr 2012
    Half a day job.
    Dec 2008
    Buffalo NY
    Ok sounds not to bad. Will have to pop the top for that..
    Southeastern Pa
    Nope.
    Flip out the condenser fan and get inside on a set of kneepads. Done a couple that way.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Dec 2008
    Buffalo NY
    Nope.
    I'm 6'5" 300lbs. I don't think I will be crawling in there. Lol
    using Tapatalk
    Apr 2012
    nice set of guages
