Results 14 to 17 of 17
    Jun 2011
    Hammond,La.
    just looked on Rotozip's page and this is the bit he used. I was close on the name. lol
    DuraCut™ Bit
    XB-DC1 Carbide XBITS™ for cutting plaster, including wood and/or metal lath. Lengthened fluting by 1/2" for greater depth of cut.
    Carbide (tip)
    1 per pack
    1/4"
    Etters PA.
    I always use a sawzall with the carbide blade, put the blade in so it faces the top of the saw, it has a smother cut that way, then drill the corners of the hole you are going to cut so you can have a second person down below hold a box tight against the ceiling. They need to hold the edge of the box tight to the line you are going to cut to prevent the vibration. Cut with high speed and very little pressure. Along with what others said in regards to alignment between the slats and informing the home owner of possible damage you should be good to go .:beer:
    Sent from my PC36100 using Tapatalk 2
    Atlanta GA area
    Quote Originally Posted by Rcb2875 View Post
    DuraCut™ Bit
    Carbide (tip)
    1 per pack
    1/4"
    Quote Originally Posted by TACKERDOWN View Post
    Between these two ideas; I think I have a plan!
    THX again for the input; this is one of the wonderful things about H-talk!
    Ga-HVAC-tech
    Beware the Dunning-Kruger effect
    Oct 2012
    Hi mate, when i have done some work on the place myself in the past, i have always used diamond drill bits and blades, always found them to be more durable and better than steel, i'm not sure if you're sorted now but you could try these guys for diamond blades they are pretty decent, if you Google fti supply they should ocme up. i hope you found that useful
    cheers
