Results 1 to 9 of 9
    Apr 2002
    Western piedmont of Carolinas
    Hobart QF1 reach-in freezer. Need info please.
    Looking at a freezer w/iced up coil. Only drawing .4 amps on defrost. I'm thinking the element should draw much more than this, maybe this is just the pan heater. I'd like to find a manual on this so I know what I'm looking at. Anyone know where to look? Thanks
    Oct 2011
    Chicagoland Area
    Check voltage @ the element and heater safety if so equipped. You should be drawing ALOT more than that.
    May 2012
    Winnipeg, MB
    Often the watts will be stamped on an element using the voltage you could figure out the amps that way to.
    Jan 2010
    If the name plate is still intact it would be listed there.
    Apr 2002
    Can't figure out how to get to it. I'm an a/c guy, don't see much of these. The evap section appears to be sandwiched inside an insulated box w/a latched lid, and gasket in between. I lifted the latches and tried to pry it apart w/o luck. Could the two portions be frozen together w/the ice build up? I didn't want to deform anything prying too hard.
    Jan 2010
    [QUOTE=mlock;13193881 Could the two portions be frozen together w/the ice build up? I didn't want to deform anything prying too hard.[/QUOTE]
    Oh ya... happens all the time. If you force it you will most likely separate the steel from the foam. Try some warm water. Or someone will have a better idea.
    Oct 2011
    Chicagoland Area
    If they have another freezer, have them pull the product and shut the box down for the night.
    Jul 2002
    SE Texas
    Quote Originally Posted by mlock View Post
    Yeah, as mentioned, pull the product, unplug the box and let it thaw out. After all, it can't be working too well if the evaporator coil is iced up. Check the defrost clock, too.
    With your chrome heart shining in the sun, long may you run.
    Apr 2002
    Thank you. Yes, I had them shut it down for their own good, but it will help me too. Should I be able to locate the part at the typical hvac supply house (Baker, Dickson, etc.)?
