Results 1 to 8 of 8
    The Alamo
    Trane XL950 stat
    I have scanned all the literature that comes with the stat and I cannot find anywhere what to do with the data I retrieve from the SD card once I am done logging for a period of time.
    Any answers out there?
    The card shows .slg extension I think.
    Read, read, read!
    Elkton, MD
    Quote Originally Posted by sarge View Post
    The System Zone View Monitor software is required to utilize the data stored on the SD card. This is available for download to American Standard and Trane dealers through AS Dealernet or Comfortsite and further instructions can be obtained from your Field Service Representative.
    Quote Originally Posted by hvac-master View Post
    R U SURE?
    The Alamo
    comfortsite>login>password>.........where do I go from here?
    Read, read, read!
    Elkton, MD
    Tech Support>System Zone View Monitor Tool
    Install the SZVM Runtime Engine First
    Install the SZVM Second
    The Alamo
    thanks.
    You're the best....the very best.
    Read, read, read!
    The Alamo
    It appears that I do not have access to the SZVM but rather the older WinZone (I already have that)
    Hmmmmmmm.....Trane....controlling dealers.......not sharing product data in a timely and efficient manner.....??????
    Read, read, read!
    Is it possible to get hold of the System Zone View Monitor Tool other than from the comfortsite?
    I have a comfortlinkII hooked up to the xc95m with 3 zones and keep getting SOP.004.54 alert thrown and all the zone dampers are opened and zoning is switched 'off'. I've dumped the diagnostics file and curious what info it contains.
    If anyone can help I will be most grateful.
