Results 1 to 13 of 14
    Apr 2009
    Westinghouse Chiller HELP
    Hey guys I am working on a Westinghouse chiller. This is a package chiller unit. Info is as follows.
    Style 351A967G19
    Serial DH6513
    Type PBK 2150
    Upon arrival the resident maintanence guy told me the last person there has reclaimed one stage and emptied the oil in the compressor. I am just trying to figure out what is the freon charge for the chiller. Both stages if possible. It originally had a leak, and then he reclaimed 30lbs. So I have no idea how much is supposed to be in there. I have called Mcquay and left several voice mails the past week with no response and the last two days have been on hold for 30min each day. Any help would be greatly appreciated. I have found nothing online either.
    Apr 2012
    Paper Street Soap Company
    ? To quote the repair ?
    Ohio
    Have you read the units info tag?
    Apr 2009
    There is nothing on the tag other than the water and freon pressures. The name and model and serial and type that I listed. That is all I can find on it. I am fed up with Mcquay I called again today and left 2 voice mails and was on hold yet again for 45 min this time.
    Apr 2009
    Quote Originally Posted by commtech77 View Post
    Just need the freon capacity and then I can quote it yes....
    Somewhere in the world.
    It is most likely R12 but you could look at the expansion valves check out the power head.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Apr 2009
    Quote Originally Posted by york56 View Post
    I never even thought of that, I was thinking it was R22....
    Apr 2009
    I got in touch with the manager at McQuay and he told me this unit was a dinosaur....lol. Built in Aug of 1974. Uses R22 and depending on the barrel size it either takes 73lbs or 113lbs of freon per circuit. So now I am on my way back to figure out the barrel size. Its either 18" or 24." Thanks guys!
    Apr 2012
    Quote Originally Posted by Vetteman012002 View Post
    1974 ? That was back when the old timers used R12 as a degreaser.
    Good luck.
    Jan 2011
    With a boiling point of about -22*F R-12 wasn't a very good degreaser. R-11, on the other hand, with a boiling point around room temperature made a great degreaser. Washed many a part with it into the mid 80's.
    Aug 2009
    Prattville, Alabama
    Quote Originally Posted by KnewYork View Post
    Ahhh the good ol' days!
    Yea the montreal protocol took all the fun out of it remember the days of blow and go.
    Jul 2009
    In a mechanical room....
    Aren't those the chillers that were supposed to last forever and did not need oil changed and so forth for power plants and such?
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
