    May 2012
    magic chef heat pump
    I have a condo that has an in the wall magic chef heat pump. When i turned on the ac this year, the whole coil froze up like a block of ice. Someone said it may be the defrost coil. Any advice would be appreciated. Thanks
    Quote Originally Posted by servicetech1949 View Post
    I have a condo that has an in the wall magic chef heat pump. When i turned on the ac this year, the whole coil froze up like a block of ice. Someone said it may be the defrost coil. find someone else or ask them just what is a defrost coil
    which coil?
    frozen coils have 2 broad reasons, air flow or refrigerant, problems with either will freeze the coil
    May 2012
    I think it only has one coil, it is the one behind the filter. It is a single stage system? I have only ran it twice this year, and each time after it running for awhile, it would be froze up like it does in the winter when its really cold out, but obviously the defrost relay was working because it would eventually thaw out. Thanks for your help
    Boise, ID
    If the filter and coil are clean it's probably short on refrigerant. You need to call a pro.
    Politicians need to be changed like diapers, and for the same reason.
    Mark Twain
    May 2012
    Thank you, now i know where to start.
