Results 1 to 13 of 19
    Dec 2010
    Woodbridge Twp, NJ
    Trying to find a permanent solution..
    I have this rooftop that is vibrating so bad, it's causing the fan blade of an adjacent condenser to come into contact with something and shatter. Ive put rubber feet under the unit to try to isolate the unit but it keeps happening. Any thoughts?
    Every customer you take for granted today will be someone else's tomorrow.
    Dec 2010
    Woodbridge Twp, NJ
    California
    The compressor in the unit causing the vibrations might be FUBAR.
    Even though it's making set point, the compressor could still have a busted connecting rod causing the excessive vibrations.
    Seen it before on Racks with excessive vibration busting discharge lines.
    Dec 2010
    Woodbridge Twp, NJ
    It's a Trane rooftop A/C and the main vibration is from the blower and condenser fan motors. It vibrates like craxy when the fan is just on and when the cooling kicks in, it's nuts.
    I'm quoting the guy out a new rooftop unit so hopefully that will help.
    Oct 2011
    Chicagoland Area
    Is it feasable to just relocate the condensing unit another 10ft from the Trane? Should take less than a day to extend the lineset and electric.
    I'm suprised the evap coil utubes on the a/c hasn't started to leak. That was common in those units
    Dec 2010
    Woodbridge Twp, NJ
    Not really. It's a small fast food joint and 10' it will be off the roof.
    Give it time, they'll probably leak too.
    Oct 2011
    Hull
    It vibrate without the compressor running? Maybe a unbalence fan blade or a bearing?
    Oct 2009
    Raleigh, NC
    The vibrations are not normal. You need to find out what is causing the vibrations and fix it. Attempts to dampen the vibrations will most likely be unsuccessful, especially in the long run.
    Apr 2012
    Jackson, MS
    If most of it is from the blower then u could just replace the blower motor and wheel if its belt driven then replace the bearings
    Dec 2010
    Woodbridge Twp, NJ
    I never said i didnt know the cause of the vibration. It's the blower wheel and the condenser fan motors. Ive already talked to the owner a month ago and he's not interested in putting good money in a bad unit. My question is does anybody have any ideas about keeping th vibration down (if not from the RTU, then something else) and have this thing stop shattering blades.
    SE Michigan
    Perhaps mounting (better) rubber isolation bushings/grommets to where the condenser fan brackets attach and blower motor bracket. Maybe remove the blower housing and lay down some foam tape...double it up even, then fasten down the housing.
    Might just be a bandaid though.
    NE Alabama
    Tell him you have already performed your quota of miracles for the month and if he wants this unit to work he's gonna haqve to cough up some actual money.
    Apr 2012
    Jackson, MS
    It sounds like he's already putting good money in a bad unit replace the motors and blower wheel I'm not to big on rigging junk it sounds like he's happy in his poopy diapers
