Results 14 to 25 of 25
    Quote Originally Posted by commtech77
    Timers were checked during PMs.
    You can imagine we thought of telling the gas station attendents to wait. You might as well try and have a conversation with the Slurpee machine.
    Sorry, but I'm not responsible for their stupidity, and I charge extra to fix it.
    May 2009
    north of 53
    Sounds like a " A/C is too cold fire up the furnace crew" working. They are good for business.
    Southeastern Pa
    I use nothing but manual reset controls.
    Yes, they create a lockout condition but, without that, sometimes, you'd never know that there was a problem.
    I LOVE that red button!!!!!!!
    Could be worse .. there's guys out there that find open pressure switches & say the switch is bad not even knowing what the pressure is
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by hvac wiz 79 View Post
    When in doubt, jump it out
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    I flipped on a guy once for telling me "It was tripping on high pressure, so I just adjusted the switch a little to stop it"
    Jan 2010
    Did you adjust it to 500 ?
    Apr 2012
    Jackson, MS
    I've always been in favor of protecting the system. With manual resets it may cause emergency calls but it eliminates most of the ( well its been acting up for 2 weeks ) calls that auto resets gives you and I don't mind the ot.
    Sep 2010
    San Diego
    High head pressure
    It seems in my case the previous techs and owner just ignored the problem becasue of the automatic switch. I even had the relief valve blow because one of the switches failed from too much cycling. After installing a manual switch it put the owners feet to the fire. It looks like their gonna fit in a new condenser in the next budget.
    Jun 2008
    Rochester, NY
    I prefer manual reset myself. If it trips...that means it tripped for a reason and the problem needs to be addressed to prevent anymore potential damage to the system.
    It helps us techs cover our a**. There has been many times in my experience where the client is aware the system isn't working properly, but still working intermittently and short cycling, and they'll wait a week to call in for service because they think it will magically fix itself. I've seen it too many times. And it's usually at 3 o'clock on a Friday when they call in and they need it fixed now!!!
    Auto reset is okay for trouble shooting or used temporarily while the real issue is addressed. But when the job is done and I walk away, I make sure it's set for manual.
    Jun 2011
    FLORIDA
    I am old school i use manual reset,
    Apr 2012
    winnipeg
    yep me to..... if you won't pay to clean condensers your gonna pay for the emergency call........ let me do maintenance i will install auto re sets.....
