Page 1 of 4 1234 LastLast
Results 1 to 13 of 44
    Apr 2010
    Ontario
    How do you deal with a leak in walk in freezer
    How do you you guys deal with a refrigerant leak in walk in freezer. 10 ft x 20 ft freezer is loaded with product. It's his only freezer. Leak is on the rooftop condenser return bend. How long do guess I've got to bring it back online before the stuff gets questionable?
    ENJOY THE RIDE
    Dec 2010
    Woodbridge Twp, NJ
    Keep the door closed and pump it down. Isolating the damaged part of the system will really cut down evacuation time and you'll be able to get it back online sooner. I usually say it's going to be offline for 4 hours. It's always better to tell the customer it's back up sooner than expected rather than tell them it's gonna be down longer than expected.
    Every customer you take for granted today will be someone else's tomorrow.
    Jan 2010
    Might be hard to isolate being the condenser that needs repaired. I don't think he is going to get it all in the receiver. Even if he could how would he isolate it from the condenser without a service valve in between the two ?
    You can get that done quick.
    Let them know to keep the door closed, isolate it, pull the charge, braze it up, quick vacuum and let 'et rip.
    I like to have everything laid out, hooked up, ready to roll before I start. Manifolds and recovery machine hooked up, vacuum pump hoses ready, everything ready to roll
    Ohio
    I would think dropping the temp say 5-10*F an hour or two before the repair would help out too?
    I am not much of a refer tech but it makes sense.
    Oct 2011
    Chicagoland Area
    We all know they didn't place the service call until the food was already soft anyway.
    Jan 2010
    Peztoy,
    Can you get to the leak ? Or are there non removable covers ?
    Haha so true .. my customers tend to only pull the ice cream except mini marts in gas stations they leave it . . .
    May 2009
    The Pas, Manitoba Canada
    Quote Originally Posted by zw17 View Post
    Can it pull down when it's low on gas? Adding gas to freeze product might take a lot of time and gas. Customer is understanding type?
    Ohio
    Quote Originally Posted by K_Neil View Post
    Yes it can pull down with less gas.
    The gas was already added to get them through until the repair could be made, no customer is going to lose a freezer full of product over a few pounds of gas.
    My question is, is there a reason why you would NOT drop the box temp as low as possible before shutting the system down for repair? I would think the lower temps would allow for more repair time or some fudge factor incase things go south with the repair?
    Apr 2010
    Ontario
    I'll need to do some cutting around the return bend for room to braze, chop out fins. Lowering cooler temp not a bad idea. Being a freezer I'm concerned about too little time on the vacuum pump. I don't need moisture in the system and a frozen txv orifice.
    ENJOY THE RIDE
    Jan 2010
    Quote Originally Posted by Peztoy View Post
    Sounds like the leak is at the end sheet. Those can be tricky if it's on the inside.
    Jul 2005
    Tulsa
    put a 10 cfm Varian vacuum pump on it. this sucka weights 58lb, hardly ever put it out. too heavy unless there's a really good reason.
    shown next to Fluke 87V for size comp
