Results 1 to 13 of 25
    Chicago, IL
    best cleaner for greasy steel condensers
    I need to clean a bunch of greasy steel condensers on various pieces of restaurant equipment. Whats the best cleaner for this? I often use Alka-Brite on the aluminum condensers and it works great, but it doesn't foam on the steel ones, and takes many applications to start disolving the grease
    Jun 2011
    Hammond,La.
    Are you talking about the grease filters on the hood exhaust system? Super Clean is good and if they aren't a complete disaster I have used Awesome Cleaner that you get at the dollar store for a few bucks and that stuff works real good for all sorts of cleaning and it isn't acidic or harsh.
    "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
    Benjamin Franklin, 1766
    Jan 2010
    Quote Originally Posted by craig1 View Post
    Yep the Alka-Brite works great on aluminum but sucks on steel. Most the kitchens I work at have some good degrease solutions. Have you tried 409 or Purple Power ?
    Jun 2011
    Hammond,La.
    When I was working in the fire suppression field installing and servicing the fire systems and hoods the absolute best and fastest way to clean the worst of filters was with a pressure washer. Even the little electric models work well which is what we used since we weren't in the hood cleaning business and only did so for few clients or the job required it.
    You could call one of your local hood cleaning companies and probably get some good advice there but all the ones we worked with used high pressure machines.
    Jan 2011
    NW Iowa
    Best luck i've had is get all the surface stuff with a wire brush, spray coil with water, then spray with the foaming coil cleaner at kind of an angle, that makes it so it actually foams a little better. Then rinse the coil and do another once-over with the wire brush, and then throw a towel or something over the condenser and give it a nice blast of CO2 to knock all the crud out that the foam didn't carry out.
    Make sure you carry a bunch of paper towels or rags and put it below the coil to catch the foam/water/crud especially if its an upright unit with the condenser on top of it so the crap doesn't run down the front of it.
    Once at a chinese restaurant in town, they had a small walkin RIGHT next to the area they fried everything, and the condenser coil on top of the w/in got so plugged up with grease we literally pumped it down, recovered the rest and cut the sucker loose, took it to the carwash and cleaned the s**t out of it as a last resort.
    Aug 2010
    What's the surface plating on it?
    Lye based oil cleaner is very effective, but it will corrode aluminum and zinc plating.
    NH
    Maybe try KO Blaster... Works great on txv screens and is a good degreaser.
    Sep 2011
    Fayetteville, NC
    Quote Originally Posted by Dchappa21 View Post
    agree on that too. Just prebrush with a wire brush, then hit it up. If its really bad you may need to wire brush it again and go for a second or third application. But for easy clean up you can't go wrong.
    The foam and clean works good too, esp if there is a hot water hose nearby. Just make sure you cover the fan motor with plastic and don't go to crazy with the hose.
    Hot water in a pump up sprayer works just as good too for rinsing.
    Aug 2010
    A safe bet for anything is a foaming or biodegradable engine cleaner. Engine blocks are made of iron or aluminum so engine cleaner is safe on either.
    When it comes to oxidized non petroleum oil stains like frying oil though, there isn't anything much better than caustic based cleaners which aren't aluminum safe, but ok on steel.
    Avoid using the type that smells like diesel fuel. Because, the smell is really that horrible.
    NE Alabama
    On steel I use industrial strength degreaser and hot water. It usually takes more than one application, but I keep at it until it rinses clear. For coils where breading or flour is mixed with the grease a wire brush helps with the face of the coil.
    Mar 2012
    Maine
    I use Simple Green HD, it's actually purple. I have also used Grease Off with pretty good results.
    Viper won't take the paint off, don't stink and rinses of good with a hand sprayer.
    Viper in the can if you want foam or HD Viper if you want to mix and spray.
    http://www.refrigtech.com/Product/Co...sol/viper.html
    http://www.refrigtech.com/Product/Sp.../viper_HD.html
    Stuff works great on regular grease but real bad coils need a lot of work no matter how strong a cleaner you use IMO
    Oct 2009
    new jersey
    I used a base solution it foams nicely. Rince and use 2shop vacs. Long wide across bottom and the other in your hand. Rember dont make a mess.
