Results 1 to 9 of 9
    May 2008
    Massachusetts
    Fresh air intake?
    Found this after a couple calls of No Heat that reset itself. Roofers covered the intake with asphalt and broke the fitting. I had to replace the whole concentric vent.
    Cincinnati, Oh
    Ahh roofers. The killer of 90's since home owners found out they can go through the roof.
    "Just get it done son."
    Dad adjusted
    Years ago I found a really creative one on a Lennox Pulse furnace.
    The roofers cut the "pipe" so they could slide a new rubber flashing over it.
    The only problem is that the "pipe" was a concentric roof vent.
    To "fix" it they stuffed an empty tube of caulk into the middle exhaust part as a splice for the 2 sections, then carefully caulked around the outside with white silicon caulk.
    The roof was replaced in the spring, so the problem didn't present itself until 8 months later. The roofing company actually tried to deny that they had done the deed...
    Afton, VA / Khorat, Thailand
    That's a nice one....haven't come across that yet...
    Midnight Sun Astrophotography
    Jun 2007
    Greenwood Indiana (Indianapolis)
    Smile
    I once had roofers that cut the concentric and coupled it together on the roof. It was on a Pulse furnace. The intake was choked from the coupling and got very little air in it.
    As iron sharpens iron so one man sharpens another Proverbs 27:17 NIV84
    Jun 2007
    Darby, PA
    Quote Originally Posted by Greg414 View Post
    Seen that more than a few times!!! Looks like a leaker to a roofer!!!
    Psalm 51:10, 12
    Feb 2012
    Chile
    I saw a tarred and shingled rooftop unit today
    Feb 2012
    Toronto Canada
    We just had a a Roofer put a screw into the liquid line of a Big R-22 Fridge holding alot of Freon. I love Roofers. I seen em cut the gas pipe with the axe and then dump Tar on the pipe to stop it from leaking. Get the Call guys freaking "I cut the pipe come quick" calls back 5 min later all calm No worries I fixed it LOL
    Jan 2011
    You guys glue the tops on the concentric? I either just shove it on there or put a screw thru it.
