Results 1 to 10 of 10
    Apr 2012
    Paper Street Soap Company
    RTU Will not satisfy
    Thats the remote sensor mounted at the filter rack in front of the MAKE-UP AIR damper.
    Apr 2012
    winnipeg
    well .... you might as well posted a picture of a big mac ...what are you getting at
    I string temp stats all the time in returns but prefer to drop it lower. Today found one dead smack against the evap coil.
    Apr 2012
    See the remote sensor ? Stats downstairs taking the temp input of the sensor thats hung in front of the make up air damper.
    Fan starts, make up air damper opens mixing 90 degree air with return air and the unit never shuts off. Stat reads in the mid 80s with space temp around 69.
    Thazs what I was getting at.
    Mar 2006
    Quote Originally Posted by commtech77 View Post
    I like it nice and chilly
    You can't kiss death without it kissing you back. Death is a passionate kisser.
    Jul 2010
    So-Cal
    If the stat is mounted down stairs then I don't know why they would mount the remote sensor there! That doesn't make sense. Usually see a Accu-stat mounted inside the unit.
    Apr 2012
    Quote Originally Posted by carmon View Post
    There is a pretty specific description of "what Im getting at" above the pic in the first post.
    Assumed that was enough information for a HVAC forum. My bad.
    Apr 2012
    Quote Originally Posted by jackintheboxtec View Post
    Some commercial buildings especially restaurants will use remote sensors so all of the thermostats can be mounted in one place. Usually in the managers office.
    This is the bathroom RTU for an upscale restaurant in Houston,
    They should be located in the space but the installers got lazy and a little stupid in their placement. I don't have a problem with installing them in the return plenum but well enough away from the make-up air inlet to prevent this exact scenario.
    Afton, VA / Khorat, Thailand
    Looks more like "shoved in there" than mounted.......
    Midnight Sun Astrophotography
    Jun 2007
    Darby, PA
    Quote Originally Posted by tunnel_rat View Post
    Must have a t-stat wire shortage!!!
    Psalm 51:10, 12
