Results 14 to 26 of 37
Thread: ak900 questions
    Feb 2007
    Fremont, Indiana
    You can take it apart and clean the glass. Just as if you're changing the battery.
    Has anyone had issues with the low side consistently reading .5 inches off?
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
    Central NJ Area
    Does anyone else have concerns about using low loss hoses on your guages because of zeroing issues?
    Feb 2012
    My ak900 reads .6 HG on the low side when not hooked up to anything...is this normal or should I get it calibrated?
    Quote Originally Posted by AStudent View Post
    Press Zero.
    Florida's space coast
    Quote Originally Posted by Nytefog View Post
    I use YJ ball valves on my hoses.
    The low loss should not be a problem as long as you remember to release any pressure in your hoses before zeroing the DRSA.
    We've been doing so much,for so long,with so little, that now we can do almost anything, with nothing at all.
    Central NJ Area
    Quote Originally Posted by a\c don View Post
    Don't want to violate EPA regualtion venting reffer into the atmosphere. Thats why i had those hoses, but according to the epa they are mandatory.
    A ball valve hose end qualifies as a low-loss fitting.
    The whole low-loss thing is a joke, anyway. You're going to have to vent that residual refrigerant sometime.
    Central NJ Area
    i thought you were suppose to recover it technically speaking.
    De Minimus
    The EPA recognizes that a certain amount of refrigerant is going to be lost during service procedures.
    Venting or purging hoses is part of that.
    Feb 2007
    Fremont, Indiana
    Does anyone know how to calibrate the low side?
    Mine consistently reads 0.5 lower than high side even at standing pressure.
    Also my high side ball valve will leak by periodically (on manifold).
    Is there a rebuild kit that anyone is aware of?
    And while I'm at it....Is it normal for the low side to blink and quit reading at pressures above 130-150 psi? (even 410a)
    A Einstein
    My ball valve leaked also. I was told to tighten the Allen screw on the side. I also noticed a machining issue on the interior under site glass .. Hope it doesn't break free into system although it appears ok but you never know
    Central NJ Area
    De Minimus
    I was aware that purging hoses was ok, bu thought that the point of low loss fitting was to not vent to the atmosphere why else would they require the use? I don't understand?
    Feb 2007
    Fremont, Indiana
    So you don't blister your hands while working on a remote RT chiller condenser in 40 & under deg weather! Works for me!!
    Get real sick of the layers of skin removed that way
    A Einstein
