    May 2008
    Augusta, Ks
    Confused txv "special tool"
    Well we will see just how good you guys are. I've got a 20 ton Carrier chiller that needs TXV changed out. I can either solder in the new one or change out the " guts " of the old one. This is what Carrier is calling a cage replacement. But in order to do this I need to use the "provided" X-29151 tool. Of course the tool isn't there and none of my Carrier dealers tech support know what it is. Anybody?
    Dallas ,Texas
    Well since Carrier has made so many flavored of chillers which kind are you working on? What kind of valve is it?
    UA 100
    It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
    May 2008
    Augusta, Ks
    The chiller is - 30GTN020 air cooled , the valve is Emerson TRAE20H.
    Las Vegas NV
    pjh,
    According to the Emerson catalog the "cage removal kit" comes with the new cage if you buy it from them.
    Cage Replacement Kits for TRAE+ Series Valves Cage kits are cross referenced by capacity and tonnage in the table below. Each cage kit consists of a replacement cage and cage removal wrench. In addition, the cage removal wrench (KT-20294) can be ordered as a separate item.
    Here's the link, page 3
    http://www.emersonclimate.com/Docume...+%20Series.pdf
