    May 2012
    Thumbs up Problem with centralized air-conditioner and no temperature regulation
    A building has several rooms with centralized air-conditioner and no temperature regulation. Due to difference in preferences for room temperature the employees are facing problems. Please suggest how can we design a system using this centralized Air conditioner to regulate the temperature of our room/ surroundings.
    Help me in Designing a solution for my problem, How it is done to:
    1. Develop an On/Off Mechanism
    2. Ability of creating 3 or more levels of Cooling
    3. Switching On/Off depending upon the presence of the person
    The cost Economics should also be justified for the design.
    Jun 2010
    Philadelphia PA
    If space is consistently holding, reasonably close to set point then BALANCE to preference
    You have got to learn from other people's mistakes! Because God knows you don't live long enough to make them all yourself !!!!!!!!
    Oct 2002
    Plano, TX
    i've seen this done with duct reheat. stat controils duct heater. not real efficient so probably illegal.
    Nov 2005
    Quote Originally Posted by viveksisodiya3 View Post
    More info needed to even have an idea.
    Is this a constant velocity system?
    VAV boxes?
    Pnich box?
    VVT?
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
    Jun 2001
    San Diego, CA
    occupancy sensors and a commercial zoning kit would work well here assuming a proper air balance and ducting design.
