Results 1 to 6 of 6
Thread: Weathermaster
    May 2008
    Clovis/Fresno CA
    Weathermaster
    I have two units 48hjd008 that were installed 6 years ago but never wired. They got the phase wrong,fixed that now when call for cooling condenser fans turn on and and then turn right off comp follows on high head switch. If I push fan relay they run, cap has power replaced fan relay other unit still same problem .Any help much appreciated thanks
    East of big city prices.
    Is the second stage coming on first?
    May 2008
    Clovis/Fresno CA
    Not sure which one that is
    Quote Originally Posted by laszer99 View Post
    On the wring diagram it shows that the y1 signal from the stat brings on the OFC. If I recall correctly the first stage is on the right and second stage is on the left.
    Did you even have 24 volts on the OFC?
    May 2008
    Clovis/Fresno CA
    On one first stage comp is leaking on other doesn't come on at at all
    Place a service call with a local ac contractor.
