    Jan 2010
    DISCHARGE FILTER
    why would you use one ? Was working on a old Trane air handler yesterday. Originally water cooled but converted to remote air cooled. 2 five ton CNR-5 copeland compressors. Discharge lines go to shell type filters. Tops of filters have a 1/4" line back to compressor suction process tubes. Is it some kind of oil return ?
    The Zone
    yep oil seperators
    It's Hammer Time!
    Jan 2010
    Quote Originally Posted by mrfixinthangz View Post
    yep oil seperators
    Could you elaborate on that a little ? I'm sure the rack guys see them often.
    Oct 2011
    La.
    It is an oil seperator. Look up the brand and it will explain the operation. there is usually a float inside that returns oil through the tube to the compressor when level rises.
