Results 14 to 26 of 38
    Jul 2012
    My 88T-CMT was serviced yesterday and is now working.
    The product temperate is about 18F but when I dispense the product the head shakes quite a bit.
    Any ideas? Thanks.
    Sep 2012
    Electro Freeze CS1 Model -- Not shutting off? Help with Settings
    Hello all! I am new to these forums and I had a quick question. I have an Electro Freeze CS1 model single barrel soft serve machine. It had not been turned on in a while and it just kept running with the mix and the hopper got ice cold and the cylinder didn't seem at first to get cold enough to freeze the mix, but then after turning it off and then back on again it froze the cylinder so I stopped the machine and then I started to look at the controls the temp is set at 20 and at a setting of 4. The front switches are set at 50 seconds and the other at 40 I believe? Any help would be greatly appreciated. BTW. I took the mix out and it was frozen to the paddle so I put another one in and it never seemed to get cold enough although it just kept running? ARGGGH!
    Richmond, Virginia
    In the process of ordering a relay, door switch, and compressor contactor. Nice stuff!
    Jan 2013
    Hi! I have an urgent question. The left hopper on my 2 flavor electrofreeze machine stopped working. The left side is working fine. On the right, it's freezing and dispensing correctly. however, the (top) hopper is not cooling. What could be wrong? How do I fix it? Thank you!
    Jan 2013
    Denver , Co.
    hi im working on a cmt 30 , the cabinet temp is about 25 degrees even when the switch is off ,
    compressor kicks on every 5 min for about 30 sec , no matter what
    any ideas
    Outlaw guns? only outlaws will have guns
    Those who live by the sword are SHOT by us who don't.
    Denver , Co.
    Quote Originally Posted by EFfactoryservice View Post
    I would like to introduce myself and this seems like the logical place. I am a factory service representative for HC Duke/ Electro Freeze equipment. I will keep an eye on this board during normal business hours
    What happened to this guy , he just leave us hangin ??? kinda scary
    Ice V
    Apr 2013
    Hello I have a 44 cab older model 1989 single flavor the modle I believe is SN232 it has the syrup dispenser on the left side facing the machine
    the unit is making quite a noise
    I have disconnected the reduction gear belts so I can try to find out where the loud noise is coming from
    it would appear to be the beater motor more of a rumble but motor spins very well
    once the beater cylinder is cooled the motor stops spinning
    is there a replacement whisper quiet motor available or do I need to simple get the one I have rebuilt of for that mater is this normal for the older units
    Thanks in advance
    Doug
    Apr 2013
    Sorry model number is 44 Cab BN-278
    Quote Originally Posted by Dougjones View Post
    Hello I have a 44 cab older model 1989 single flavor the modle I believe is BN 278 it has the syrup dispenser on the left side facing the machine
    Thanks in advance
    Doug
    Sep 2011
    California
    How much current its pulling? and what is it rated to.
    Apr 2013
    Hello I am running it on a 230 volt system 20 amp breaker
    its rated for 208 volts
    I am losing a little current over all
    Apr 2013
    Also I should mention since this last post I have disconnected the beater motor voltage and the noise is gone. I am thinking an over haul of the motor is required bearing brushes etc.
    Jan 2014
    Hi there. What is your direct email?
Comfortech365 Virtual Event
