Results 1 to 13 of 39
    Apr 2012
    East Moline, IL
    Electro Freeze factory service advice.
    I would like to introduce myself and this seems like the logical place. I am a factory service representative for HC Duke/ Electro Freeze equipment. I will keep an eye on this board during normal business hours and try my best assist any questions on our equipment anyone may have. I will be the first to admit that I am no the most "seasoned" guy in our department but I do have access to those guys should I get stumped. I will stay out of "opinion" topics and not spend my time bashing our competition. So please if you have any questions on our equipment do not hesitate to send me an email
    Sep 2011
    California
    Electro F
    Great!, "J". Mod 30T-RMT-237 Ser. J2L-3604. Is there a way to check temp's at the evaporator without the product? Can I put it to work bypassing the head mag switch without doing any damages to the cylinder.
    Apr 2012
    East Moline, IL
    What are the symptoms with the machine? We really like to see a load on the evaporator. Also, what are your normal operating pressures? Some models you can run what we call a frost pattern check with the head off the machine and the beater shafts pulled out, on some models however you may have to have the head installed, again with the beater shafts pulled out. I do not reccomend running a freeze cycle with no product in the barrel and your beater shafts intalled. You can call 800-755-4545 to speak to someone live.
    Aug 2005
    iowa
    Do you have any upcoming service training? Its been 10 yrs since I've been to an electrofreeze class! Your post reminded me it might be time to go again.
    Thanks in advance
    Jeep
    Apr 2012
    East Moline, IL
    We usually have service schools starting late November and running into February. Depending on demand we do 2 schools for Electro Freeze Equipment and 2 schools for Duke (Dairy Queen) equipment. To attend the Electro Freeze school you must go through our distributor in your area. You can contact us directly to attend a Duke seminar. If anyone is interested in coming to a school please send me an email with your name, company info, and contact information as well as what school you would like to attend. All attendies must have valid EPA Refrigeration Certification. We fill the classes on a first come basis.
    Sep 2011
    California
    I do not have a problem at the moment. I did previously and I was told that I needed a load to be able to calibrate and check temp's and T/B. Which I did but a little bit messy hahaha oh well. But I had quite a few problems with this particular equipment: Evaporator cyl. press. switch, Day temp control and low press. switch.
    Apr 2012
    East Moline, IL
    I am sending you an email now. Some issues can arise depending on how the unit is set up and what mix the customer is using, however your issues may go beyond that.
    Aug 2005
    iowa
    Thanks ef
    I will get with u towards the end of september in regards to classes....
    Jul 2012
    88T-CMT MTS problems
    When I prime the machine I hear the MTS gear box kick in and fill up the cylinder. I turn every thing on and the beater turns on.
    When I dispense product the beater does not turn on nor do I hear the MTS gear box kick in.
    Any ideas what could be the problem?
    I have been calling my factory authorized dealer for a week with no response.
    Thanks.
    Apr 2012
    East Moline, IL
    Yes, it sounds like a spigot switch, but could be a couple of things. Please call 309-755-4553. Ask for Josh or anyone in the service department.
    Thanks.
    Jul 2012
    Thanks for the prompt reply.
    I will give them a call.
    Where is the spigot switch located? I can't seem to find it and also whats the difference between 88T-CMT and 88T-RMT?
    Thanks again.
    Jun 2001
    ohio
    Quote Originally Posted by EFfactoryservice View Post
    Hello and welcome. HC Duke is a great company. Is Penny and Kent still with the company?
    Nov 2010
    MN
    Electro-freeze is a great company with top notch equipment. X2 on the spigot switch, might just need to be adjusted back down.
Quality Home Comfort Awards
