    Feb 2011
    Illinois
    Tridium FX JACE and KMC
    I have a customer site with a JCI FX controller bringing in points from a KMC controller via BACnet. Customer would like to lower the setpoint. The KMC controller has a range on the KMD stat which I thought I would lower. Because the point comes across as a 'read only' point, it appears that I cannot adjust the analog variable point. Is it possible that I can change the point so that FX controller will write to the AV on the KMC controller?
    SE Pennsylvania
    If in fact it is capable of being written to, you will need to rediscover it and add it as numeric writable.
    NY
    I was initially stumped by the very same problem and the solution was just as hva69 says.
    "Controls is a lifestyle not a job" -klrogers
    Feb 2011
    Illinois
    Worked perfectly, thank you.
Tags for this Thread
